Postby AdolarRax » Fri 1. Apr 2022, 16:34
Greetings!
Nice project, I really like it! Althought I have a question about the whole project. Is it possible to add a third motor to the whole setup by writing an extra session for the third motor in the arduino programmer software. In that case, it would be possible to make the simulator fully turnable in any direction.
AdolarRax
Postby AdolarRax » Fri 1. Apr 2022, 16:36
Greetings!
Nice project, I really like it! Althought I have a question about the whole project. Is it possible to add a third motor to the whole setup by writing an extra session for the third motor in the arduino programmer software. In that case, it would be possible to make the simulator fully turnable in any direction. :roll:
AdolarRax
Postby HanssieH » Tue 26. Sep 2023, 09:45
when I download the x-pid 1.4 zip file and try to open it I get a error invalid zip file. Where can I find the correct one?
Hans
HanssieH
Postby andrewko » Sun 12. Nov 2023, 13:18
Not much life in this topic, but anyways..
@Hans
Same problem here, but I found the project files in Github (99% sure that these are the same files):
https://github.com/duarte0167/X-PID-Ard ... or-control
The .ino file is under "XPID-Arduino-Firmware" directory.
However if you need the X-sim plugin (not sure if you do, since I guess X-Sim works with XPID FW "out of the box")
you need to build the plugin yourself from "Sample windows X-Sim plugin".
I got a working 2DOF system with the FW from RacingMat's build log, but have some issues with it
so I'm planning to move to the X-PID FW.
Thanks for posting this very nice project!
andrewko
Postby andrewko » Thu 16. Nov 2023, 11:21
I've found the firmware zip in my backups (the link in the first post gives a corrupted file)
so you can find it attached.
Firmware_and_plugin_1-4.zip
(780.08 KiB) Downloaded 3419 times
andrewko
