Re: Thanos AMC1.6 USB 2DOF Motion Controller
Postby thecure » Tue 12. Aug 2014, 14:49
in this link there is a optolink
viewtopic.php?f=39&t=132&hilit=optolink&start=210
question...!...it's possible to delete the part that controls the h-bridge (....in simple terms i need a new circuit )...tks
thecure
Been thanked: 5 times
Postby Pavlado » Tue 4. Nov 2014, 00:40
Hello everyone. I want to ask whether they can be connected in parallel MOSFETs behind the H-bridge, so I increased their capacity.
Pavlado
Postby thecure » Tue 4. Nov 2014, 22:48
it's possible to have kp from 1 to 4 with a new firmware ?
thecure
Postby vicpopo » Tue 11. Nov 2014, 23:02
Hi ,
Just to report what I noticed.
I always use the awesome amc1.6 controler and last time ( it happens twice) when I launched converter it runs continuously .I noticed on the screen that it was blocked on the kangaroo interface .So I decided to unplug the amc1.6 and just simultanously converter opened .
As I didn't use the kangaroo interface I unchecked it on converter .After made I re-pluged the amc1.6 and everything works well.
I suppose the problem comes form the managing of the com port .
Postby vthinsel » Tue 13. Jan 2015, 14:08
Hello !
I'm about to enter the 2DOF family :D
I went through the 43 pages briefly.... wow !!!
I was wondering if there were some new PCB compared to the ones on the first pages. I spotted some infos on pages 3 and onwards for opto PCB and H drivers. Are those also available ? Living in France, would you recommend a PCB manufacturer (I spotted a french guy in the forum but would he be ready to manufacture some )?
I have also probably missed some generic info such as the wiring for sabertooth modules and other power modules. A "cheat-sheet" in the first post would be great.
By the way, is it possible to connect directly small PWM hobbyist micro-servo to the AMC board to do some card testing ? (I used to do some R/C cars ...)
Now I'm waiting for my components order to arrive, and FTDI board to make its way from ebay to me....
Cheers, and happy new year !
V.
vthinsel
Postby gzezelj » Sun 25. Jan 2015, 21:52
Hello everybody! Please help. I have a problem with old MAC 1.5. Controller gives only high values for POT 2, in range 800-1023. When I turn pot to minimum (around 800) controller shuts down. I tried with new pot and new ATmega8535, but it didn't resolved the problem. Obviously, some part of AMC is damaged. Any idea? See video below
https://www.youtube.com/watch?v=iMVQlXwFNxc
gzezelj
Postby vthinsel » Sat 31. Jan 2015, 23:27
Well well well.....
I have built the AMC 1.6 card but I have an issue I'm not able to troubleshoot. I programmed the ATMega644 succesfully (including fuses) using my AVR ISP MKII programmer:
Code: Select all
C:\Users\vincent\Documents>atprogram -d atmega644 -t avrispmk2 -i isp write -fs --values 0xffdcff
Firmware check OK
Write completed successfully.
C:\Users\vincent\Documents>atprogram -d atmega644 -t avrispmk2 -i isp program -c  -f "c:\Users\vincent\Desktop\18.4320 and 22.1184 crystal\fw11h18.bin" --verify
Firmware check OK
Programming and verification completed successfully.
Code: Select all
C:\Users\vincent\Documents>atprogram -v -d atmega644 -t avrispmk2 -i isp info
[DEBUG] Starting execution of "info"
[DEBUG] Starting process 'C:\Program Files (x86)\Atmel\Atmel Studio 6.2\atbacken
d\atbackend.exe'
[DEBUG] Connecting to TCP:127.0.0.1:49409
[INFO] Connected to ispmk2, fw version: 1.17
Firmware check OK
[INFO] Firmware check OK
Tool avrispmk2 has firmware version: 1.17
Target voltage: 4.90 V
Device information:
JtagId:     N/A
CPU arch.:  AVR8
Series:
Memory Information:
Address Space    StartAddress            Size
prog                      0x0         0x10000
  FLASH                   0x0         0x10000
  BOOT_SECTION_1       0xfc00           0x400
  BOOT_SECTION_2       0xf800           0x800
  BOOT_SECTION_3       0xf000          0x1000
  BOOT_SECTION_4       0xe000          0x2000
signatures                0x0             0x3
fuses                     0x0             0x3
lockbits                  0x0             0x1
data                      0x0          0x1100
  REGISTERS               0x0            0x20
  MAPPED_IO              0x20            0xe0
  IRAM                  0x100          0x1000
eeprom                    0x0           0x800
io                        0x0            0x40
osccal                    0x0             0x1
Signature:  0x1e9609
OscCal:     0x83
Lockbits:   0xff
Fuses:
EXTENDED (0b11111111):
   BODLEVEL      0x7
HIGH (0b11011100):
   OCDEN         OFF
   JTAGEN        OFF
   SPIEN         ON
   WDTON         OFF
   EESAVE        OFF
   BOOTSZ        0x2
   BOOTRST       ON
LOW (0b11111111):
   CKDIV8        OFF
   CKOUT         OFF
   SUT_CKSEL     0x3f
[DEBUG] Command "info" finished with return code 0
[DEBUG] Exit successfully.
But the LCD remains empty. I havent connected any pots yet or anything else. Should something be displayed immediatly upon power/reset of the board ?
On the USB/serial I have also something strange: I wired TX/RX/+5/GND of my adapter but terminal doesn't output a single car. When resetting the AMC, after 3 or 4 seconds the TX LED blinks constantly.
Any idea of what is happening ?
Thanks for your help.
Vincent
vthinsel
Postby tronicgr » Mon 2. Feb 2015, 07:43
I think avrdude works with hex files... the firmware is in bin format... hmmm
Postby vthinsel » Mon 2. Feb 2015, 10:04
tronicgr wrote:I think avrdude works with hex files... the firmware is in bin format... hmmm
Hello,
It is not avrdude, it is the atprogram binary file that comes with AVRStudio and it supports .bin files:
http://www.atmel.com/webdoc/atmelstudio ... ility.html
So the problem is somewhere else. But if you could provide a .hex file (for 18Mhz crystal) I could make double sure the problem is not this one.
Cheers,
Vincent
vthinsel
Postby micma80 » Mon 2. Feb 2015, 10:50
gzezelj wrote:... old AMC 1.5. Controller gives only high values for POT 2, in range 800-1023.
Hi, I make a simple observation ,
you have tried to change pot ? have you checked the cables of the pot and the PCB connection ?
micma80
micma80
