Postby kevin123 » Sat 17. Dec 2016, 22:06
Hello sirnoname, which button? You mean this?
4240
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby sirnoname » Sun 18. Dec 2016, 02:13
Yep, the small arduinos are limited with frequencies. Bigger ones can do more accurate switchings.
Postby kevin123 » Tue 20. Dec 2016, 12:14
Thank you for your reply and sorry for the delay.
so the problem is one that Arduino is limited, even though the code would change the frequency not the would manage the appropriate way, I understand you correctly?
What would you recommend me to solve the noise problem in the engines, arduino mega?
kevin123
Images: 132
Postby Mucilon » Wed 25. Jan 2017, 20:54
I'm using this bridge H, in this scheme, just by changing pin 10 to 9.
http://i64.tinypic.com/2zxp534.jpg
It is working in reverse, set out position to 10% the motor does not move, I take the potentiometer manually until the 10% it works. When it was meant to be inverted.
Can someone help me solve this problem?
Mucilon
Postby pippo23010 » Mon 6. Feb 2017, 23:17
hello guys I have the same problem Mucilon,please help !!
I wanted to also ask that code x pid goes to put ibt 2? Thanks in advance
pippo23010
Postby EICH » Thu 11. May 2017, 19:31
Hi There
Very nice Firmware. But i have a problem, that i cant open the Arduino X-PID Dialog window. In my case it is called: X-PID 1.4 COM4 position 1 for the right actuator. i can give him an output value and set the Value with the "Set output" button, the motor then moves to this location.
I just installed the x-sim software and read the starting wizard. What do I need to do, to set up the x-sim software?
Thanks for yout time.
EICH
Images: 8
Postby ebezerra » Sat 3. Jun 2017, 08:51
Greetings,
I see a lot of use of the monster shield for two motors (actuators). But has it been used the same in brigde mode for only a single motors (actuators)?
ebezerra
Postby sirnoname » Sun 4. Jun 2017, 11:00
Sorry, this is a question for a arduino forum ;)
Postby skihnia » Thu 10. Aug 2017, 15:56
Thank you sirnoname for the software!
I have 4DOF with 360° yaw. I'm having hard time calibrating POT min and max values for the yaw. Signal is quite jumpy near 0 and best I have got so far is min 47 and max 997. Now when moving over 0 position I get quite bad jerk.
Any advice how to get rid of the annoying jerk.
skihnia
Postby aliorabi0 » Sat 2. Sep 2017, 01:48
I think that is a great project i wish if i can do the same project and simulate movies ;)
Alicio
aliorabi0
