Postby TheXRacer » Sun 12. May 2013, 18:07
Here my Setting , can anyone check this i use Firmware 1.1d :
TheXRacer
Images: 9
Has thanked: 5 times
Postby vicpopo » Sun 12. May 2013, 19:05
Hi ,
Why didn't you use the last Firmware g I believe.
Best Regards
Postby TheXRacer » Sun 12. May 2013, 19:09
Can you send my your Converter (USO Setup) Data ?
Thank you !
best regards
Christian
TheXRacer
Images: 9
Postby vicpopo » Sun 12. May 2013, 19:45
It's correct in Uso parser , you could just put 1ms instead 33ms for the delay to send datapaket.
There is a 4 deepswitch button . Just put the first to on ( LCD display ON).
Use the latest Firmware !
Postby kbssa » Sun 12. May 2013, 21:20
Hi TheXRacer,
what crystal are you using ? If you are using the 22.1184Mhz crystal try to change to the 18.432Mhz one and your problem finishes.
Bruno
kbssa
Images: 16
Postby TheXRacer » Sun 12. May 2013, 21:32
Hello Bruno,
I using a 22.1184Mhz crystal i can not upgrade to a 18.432Mhz , i have any in my hobbiebox :P .
Thanks for your answer i will testet it !!!
best regards
Chris
TheXRacer
Images: 9
Postby TheXRacer » Sun 12. May 2013, 21:35
:lol: :P :P :P :P :P :P :P :P Hey i have a 18.432Mhz i test it an write in the next time the resaults .....! :P :P :P :P :P :P :lol:
TheXRacer
Images: 9
Postby kbssa » Sun 12. May 2013, 21:50
TheXRacer wrote::lol: :P :P :P :P :P :P :P :P Hey i have a 18.432Mhz i test it an write in the next time the resaults .....! :P :P :P :P :P :P :lol:
Ok man, let me know when you have tested it!
Bruno
kbssa
Images: 16
Postby TheXRacer » Sun 12. May 2013, 22:02
Yes :D Bruno :D Yes :D Bruno :D Yes :D Bruno :D Yes :D Bruno :D Yes :D Bruno :D Yes :D Bruno :D Yes :D Bruno :D Yes :D Bruno :D
You solved my Problem i chanched the 22.1184MHz to 18.432MHz an all works to 1000000000000 % !!!!! :lol:
:lol: I Thanks all people were help my BIG THANKS !!! :lol:
Biggest regarts
Christian
TheXRacer
Images: 9
Postby kbssa » Mon 13. May 2013, 00:53
Yes man !!
Glad you have solved your issue. But I have one suggestion for you. Why don't you make a PCB board instead using a prototype board ? that boards aren't so good !
If you interest yourself I have some professional AMC 1.6 boards that you can see here: http://www.x-sim.de/forum/viewtopic.php?f=7&t=862
Let me know if you get interested.
Bruno
kbssa
Images: 16
