Pololu JRK 12v12 / 21v3 High Resolution Plugin
Re: Pololu JRK 12v12 / 21v3 High Resolution Plugin
Postby ferslash » Thu 24. Jan 2013, 07:17
sorry, i meaned to write: "what are the values that i should use in the x-sim converter program," the ones posted by sirnoname at the beginning of this post or other values.
best regards... and now reading all the documentation
fer
ferslash
Postby amoras10 » Thu 7. Feb 2013, 21:23
Who, has good saved x-sim profile and can share?
I just edit it according to my port etc.
Thanks ;]
amoras10
Postby motiondave » Thu 7. Feb 2013, 22:46
amoras10 wrote:Who, has good saved x-sim profile and can share?
Thanks ;]
The profile for motion is not port restricted , the only thing you would need to do is maybe invert forces to suit your set up. As well as number changes in forces.
What game profile are you looking for ?
Postby motiondave » Thu 9. May 2013, 08:05
lazy me finally is using the plugin.
motion is good. I can feel finer motion like more road vibration.
Well done Sir on the plugin development. :D
heres some screen shots that may help. I am having issues getting a vid tut done.
I found that in interface settings, you need to click "add new sequence block" a step thats not too clear it seems.
I couldnt work out why the converter was starting and jrks were on , but no motion, until I clicked this for each and hey presto, working plug in.
yes I know photos are out of sync, dammit.
photos steps are
interface
output settings one
output settings 2
program
Postby jimakosgr2002 » Sun 16. Jun 2013, 12:55
IN my interface setting i see pololuJRK but when i click open setting in the box select detectend i cant find any jrk controler
why?
jimakosgr2002
Postby sirnoname » Sun 16. Jun 2013, 13:27
Screenshots and tell us the version of X-Sim and plugin you use
Postby prodigy » Sun 16. Jun 2013, 14:16
jimakosgr2002 wrote:IN my interface setting i see pololuJRK but when i click open setting in the box select detectend i cant find any jrk controler
why?
Do you see your JRK controller connected in JRK Utility?
Postby jimakosgr2002 » Sun 16. Jun 2013, 21:06
POLOLU CONFIG UTILITY 1.4 XSIM SET UP 3.0.1.5 BETA ALUMINUM POLOLUPLUGIN VER3
jimakosgr2002
Postby jimakosgr2002 » Sun 16. Jun 2013, 21:18
i have 3 jrk12v and is conected in the jrk utility whith older version from * with force sender and uso it was all fine.maybe beta sim motion converter dont work with high resolution plug in?
jimakosgr2002
Postby sirnoname » Sun 16. Jun 2013, 23:46
As written, screenshots are needed, also screenshot from the USO.
Users browsing this forum: No registered users and 21 guests
