Postby continental » Sun 3. Feb 2013, 22:18
vicpopo wrote:Hi ,
As it's difficult to watch on the photo , I attached below a picture for the shematic.
The attachment 381613340.285942.jpg is no longer available
Please check also your baud rate in fdti driver , 9600 .
Why does your wiring look different that what Thanos video. All our wires look the same but i do not have ground connected. I have mine exactly what Thanos video on the first page of this Post.
Alonso
continental
Postby vicpopo » Sun 3. Feb 2013, 22:38
Hi ,
My wiring is the same , the cable (orange) as Thanos made is unnecessary (checked with him).
Try with gnd cable.
Best Regards
Postby continental » Sun 3. Feb 2013, 22:49
vicpopo wrote:Hi ,
Try with gnd cable.
Best Regards
Yeah i have added the ground like yours and i still get the same error. I have ordered a new chip i'm hoping that is the problem.
Alonso
continental
Postby vicpopo » Sun 3. Feb 2013, 22:53
Hi ,
Not sure !
Did you check com port setup?did you have the last driver?
I sometimes had this problem "read signature error",try twice ... And before reset button
Postby continental » Sun 3. Feb 2013, 23:05
vicpopo wrote:Hi ,
Not sure !
Did the error give you FF FF FF as the switches? I'm using windows vista... do you think i should try with another operating system like xp?
Alonso
continental
Postby tronicgr » Mon 4. Feb 2013, 00:20
continental wrote:Hey guys i have build the AVR motion controller, but when i go to program it i get the following error.
Read Signature Bytes=> FF FF FF => ERROR
Is this means i have killed my ATmega CPU?
Alonso
Did you try to run the "first program fuses fw11h18.bat" (firmware 1.1h). It set the fuses once for correct crystal speed.
Postby continental » Mon 4. Feb 2013, 01:13
Alonso
No i had not run the program. My crystal is 22. MHZ.....should i still run set the fuses?
Alonso
continental
Postby continental » Mon 4. Feb 2013, 01:27
I did run set the fuses but i still get the same error.
Alonso
continental
Postby tronicgr » Mon 4. Feb 2013, 03:09
Two more suggestions:
Make sure the FTDI breakout board is set for 5V (there is a solder jumper that you have to clear and solder it again at 5v marking)
Make sure you have the latest FTDI drivers installed manually... the ones installed by microsoft automatically are not the latest!
Postby continental » Mon 4. Feb 2013, 03:17
tronicgr wrote:Two more suggestions:
Both yes.... i check the voltage and i get 5 volts. I also check the driver and using the latest driver. Thanos have you had any issues using windows vista to program the board?
Alonso
continental
