SCN5 / SCN6 Software Thread
Re: SCN5 / SCN6 Software Thread
Postby mino74 » Sat 2. Nov 2013, 15:10
mr sirnoname
sorry about that but i am doing my best if you show me screen shot how to do it that will be helpfull my computer is in french and you asking for something i do for the first time ever
regards
mino74
Postby sirnoname » Sat 2. Nov 2013, 15:23
Also post the informations about your adapter. Internal loopbacks are written down in the manual.
You must not be sorry, you have all the time you need. Step by Step.
Postby mino74 » Sat 2. Nov 2013, 15:25
Doc6.docx
(176.93 KiB) Downloaded 1419 times
ok then i think this is what you want !!!
mino74
Postby mino74 » Sat 2. Nov 2013, 15:35
my adaptor is usb-rs485 DEVANTECH how and where we can get more infos.?
mino74
Postby mino74 » Sat 2. Nov 2013, 15:55
ok
i have to re start all over again the wiring of actuators snc5 150 mm 2 wires from snc5 to usb rs485 THE BLACK ONE NOT WIRED ? ok.?
my ilk color is gray is it right or i have to wire the brown one as shown on mirai wiring ?
START CONVERTER FIRST OR EXTRACTOR FIRST ?
mino74
Postby mino74 » Sat 2. Nov 2013, 16:01
Doc7.docx
(320.6 KiB) Downloaded 1446 times
this is only what the converter find all the time
mino74
Postby mino74 » Sat 2. Nov 2013, 16:25
Doc8.docx
(168.26 KiB) Downloaded 1406 times
this what shown when trying to scan hard disk via converter
mino74
Postby sirnoname » Sat 2. Nov 2013, 17:42
I talked about this one:
http://www.serial-port-monitor.com/
But your find is very interesting ;)
The screenshot is correct, but I need a view from Receive to Transmit.
Post your adapter infos.
Postby mino74 » Sat 2. Nov 2013, 18:54
Doc9.docx
(472.7 KiB) Downloaded 1421 times
IS this the right way to enable debugmode for snc5 .?
and i am running windows 7 is the link you send is usefull .?
and the check the screen shot is it the right way to enable debug mode or i have to do something else ?
mino74
Postby sirnoname » Sat 2. Nov 2013, 18:57
Debugmode must be set to 1 (see picture).
I think you do not need the debug mode anymore because we know the error. Set it to 0.
Win7 32 bit should work with the serial port monitor.
Send me your adapter manual or buy link.
