Postby sirnoname » Tue 4. Sep 2012, 12:30
If x-sim hangs up this is something completely different. There is no bidirectional communication with the AMC, only a stupid output. This cannot hangup if the virtual comport driver is working.
Thanos AMC1.6 USB Motion Controller
Postby vicpopo » Tue 4. Sep 2012, 13:03
Hi lj1202,
On the first page from this topic you can download the terminal21... app.With this app.you can test if the connexion with the com port is ok from the amc.
Bitrate 115200 8 bit no parity no control or no check , and click connect .In the app window you can check if the communication is ok.Thanos made a video on the first page of this topic
Best Regards
Postby Roadster2 » Tue 4. Sep 2012, 20:20
Hi Thanos. Where can we download the files for the latest version of the AMC 1.6 pcb, the smaller one ?
Roadster2
Postby vicpopo » Tue 4. Sep 2012, 20:26
Sorry , mistake from me sending reply.
Postby fooons » Tue 4. Sep 2012, 23:39
What setup should I use for the AMC 1.6 to use the encoder feedback instead of pots?
fooons
Postby vicpopo » Thu 6. Sep 2012, 19:29
fooons wrote:What setup should I use for the AMC 1.6 to use the encoder feedback instead of pots?
Hi fooons,
A few weeks ago I asked the same question and Thanos answered to me that I couldn't use this components with the amc1.6 board.
He used this encoders with his new amc6644usb that you can watch on his blog I believe.
hope he will answer soon ... If someone knows where is Thanos !! ;)
Postby tronicgr » Thu 6. Sep 2012, 22:51
ne02005 wrote:Hi guys, I build my new AMC 1.6, I coud program it OK!!!! just in seconds...
BUT
When I press "START" on X-sim the board reboots and show strange characters... what can it be?
Anybody has the same problem?
I´m testing with Xsim 3 and another old Xsim.
Your ATmega1284p may be overclocking in-tolerate.
In that case you might have to use different crystal speed. Here is a compiled version for ATmega1284p and crystal 18.432Mhz:
FTISP for AMC1.6 1.1f atmega1284p 18.432Mhz.zip
(10.97 KiB) Downloaded 1172 times
Try it and let me *
Postby tronicgr » Thu 6. Sep 2012, 22:58
Hi fooons,
Quadrature encoders are not implemented yet. After all other issues are sorted out and have some free time for this, we will see what happens. There is a lot of things involved about them that makes them a little hard to use after all.
Postby vicpopo » Fri 7. Sep 2012, 00:11
Hi Thanos and everybody ,
I made a new test with asynchronus gearmotor and inverter.
It's look better because I changed some parameters and the motor was wrong wired .It was in star instead delta.
The inverter provide from single phase 220V 50Hz ,3 phases 220 V to the motor with various frequencies.
Gearmotor :
Power 0,25 kW
Gear ratio : 100
Output rpm: 12 with 140 Nm with motor at 1400 rpm.
A little more information about inverter parametring:
1 - The motor is controled by the inverter in VFC mode (Vector Flow Control).this setup is recommended for dynamics applications where high torque is always needed to assume the whole charge(load+ dynamics )
2 - A braking resistance is used
3 - I had the max current seted to 106%, I go up to 150% (I have to check that the motor temperature doesn't go up 80 ° celsius degrees)
5 - The ramp is as follow : 0V setpoint = 0 Hz, 10V setpoint = 100 Hz (3000rpm), with a ramp up and ramp down to 0.1 seconds. I have to check this in full load and if I can increase this to 0.2 s without bad sensation playing with the simulator ,the motor would better drived as requested for always maximal torque.
6 - In the inverter in VFC I do have a dynamic boost function activated , which I have not modified its base settings.
I know that this motors and inverters aren't cheap but I just would like to schow that this solution seems working perfectly with amc1.6 and X-sim3.One more times ( in fact thanks thousends times) thanks to Thanos,and Sirnoname for his amazing products and for sharing all to us.
I made a video with this last test:
Best Regards
Postby tronicgr » Fri 7. Sep 2012, 17:31
Thanks for the details!!! Lots of people will be interested in that.
Just a note, If you disable the LCD update (DIP SW1 to OFF position) you will get even better updates more accurate positioning.
Best Regards,
