Postby tronicgr » Fri 4. Jan 2013, 17:42
That's funny, I ported the code for my AMC644USB (6DOF) into a Arduino Mega two days ago. I got it running up to 500kbps Baud with x-sim :D
But then I had to disconnect the DTR line because every time I was trying to connect and disconnect I had the damn thing reset :lol:
Postby prilad » Fri 4. Jan 2013, 18:04
tronicgr wrote:I ported the code for my AMC644USB (6DOF) into a Arduino Mega two days ago. I got it running up to 500kbps Baud with x-sim :D
Good job, congratulation :D
I can make firmware with 500 kbps baud, there is no problem. But I (as you know) don't think that it necessary... ;)
Regards,
Ale
prilad
Been thanked: 37 times
Postby vicpopo » Fri 4. Jan 2013, 18:33
Hi Ale,
Nice to see you again and watching your great job.
Best Regards
Postby tronicgr » Fri 4. Jan 2013, 18:53
Regards,
Ale
You are right. Its not necessary for 8-bit resolution... ;)
Postby sirnoname » Fri 4. Jan 2013, 19:34
Can you plz answer my question?
Postby prilad » Fri 4. Jan 2013, 19:43
sirnoname wrote:Can you plz answer my question?
sirnoname wrote:Do you have a PID count/second for me?
What do you mean? Now program cycle period (with PID-calculation for both channels) = 3.6ms. I can reduce it, but why?
prilad
Postby sirnoname » Fri 4. Jan 2013, 20:10
Yes, I mean the cycle for both motors.
10ms is the minimum for a simulator control
1ms is for vibration control (and of course much power)
This are the values that are used by the FF wheels by the game programmers.
Postby prilad » Fri 4. Jan 2013, 20:20
sirnoname wrote:Yes, I mean the cycle for both motors.
What do you advise me? Reduce the main cycle priod to 1 ms?
prilad
Postby sirnoname » Fri 4. Jan 2013, 20:58
No, its OK, you can make a slider from 10 to 1ms like the pololu if you like :)
Pololu uses 10ms as standard, so I think most will use 10ms.
Now the only missing part is a plugin for X-Sim.
Postby motiondave » Sat 5. Jan 2013, 09:13
A plug in would be nice , but what about a code that actually works!
Also , being able to source boards , components, etc. is of importance.
