Postby sirnoname » Wed 30. Jan 2013, 00:52
L298: 4Ampere is for pussies.
You can connect it.
Postby ericRacer » Wed 30. Jan 2013, 04:38
Very very good work sirnoname ! that is exactly what i was waiting and looking for !
I made my simulator with 2 arduinos because i was not able to have a stable output with only one , i had problem with pid sampletime and serial communication (pid was disturbed by serial), that was too much for me to fix it. i am not a programmer ! then...My first arduino receive the data, convert it to PWM and the second for pid calculation. I know that it's not the best but it's works very well now !
For now, i am so exited to try your code ! :mrgreen: i installed the x-sim plugin , downloaded the firmware into my arduino duemilaove (atmega328) but the interface doesn't detect my board . I don't know if i forgot something . I will check that tomorrow ! :D
thanks
ok, i just try it back downloading and that works ! my arduino board is detected ! :D :D :D
ericRacer
Images: 36
Postby Roadster2 » Wed 30. Jan 2013, 12:48
BobBuilt wrote:Sir lists a couple of good drivers at 40 odd amps try to find theses as the code is written for them and supported by sir (as in he has tested them).
Hi Bob. Where are these driver boards listed. I was looking at the 60A+ Dual Motor Driver Drive Module (eBay 330854284636). I know that Thanos has tested these but don't know if Sir has.
Also, on a four 190W motor setup (3 DOF D-Box type motion) is there any preference/advantage in running (a) 1 x Arduino and dual motor controller running the Front motors and the other Arduino and dual motor controller running the Rear or (b) 1 x Arduino and dual motor controller running the Left motors and the other Arduino and dual motor controller running the Right.
Roadster2
Postby zecaEU01 » Wed 30. Jan 2013, 13:59
Good morning everyone
Remaking the question of the potentiometer: the type below is good for our type of work.
http://www.digikey.com/product-detail/e ... -ND/297614
ZECA
zecaEU01
Postby sirnoname » Wed 30. Jan 2013, 15:42
Depends on your unknown hardware setup. This is a ten turn pot and you must fullfill the written mechanical pot solution with 0V on start and 5V on the end of your actuator way.
Postby ericRacer » Wed 30. Jan 2013, 16:08
Problem detecting !
I don't know why but every time i unplug my arduino , XPID plugin doesn't detect it, i have to download the firmware everytime into my arduino for working.
do you know what ?
ericRacer
Images: 36
Postby sirnoname » Wed 30. Jan 2013, 16:25
Yes I know that.
If you upload the firmware the rs232 converter on the arduino get better initialized than with my plugin code.
I thought it is solved but it seems to be not working for you.
I am searching for windows host source code which explain how I have to init the arduino to work as the firmware upload do.
The last change I did was to init the DTR/CTS lines which has solved this on my device and which I saw in a sample code.
There is a trick I did not found for now how the firmware upload is failsave to init the converter speed and I not.
Will now install the serial port monitor and sample the exact solution with a firmware upload and try to implement this init into the X-Sim plugin.
Postby telfel » Wed 30. Jan 2013, 16:26
zecaEU01 wrote:Good morning everyone
ZECA
Hi I have tried these with Uno and Sir,s firmaware
http://www.digikey.co.uk/product-detail/en/6127V1A180L.5FS/987-1392-ND/2620661
the min reading was 40 the high reading was 980
these are 180 deg contactless hall effect sensors
regards Terry
telfel
Images: 54
Been thanked: 9 times
Postby sirnoname » Wed 30. Jan 2013, 17:02
Ok, got it.
The arduino GUI do switch from 9600 to 115200 and then try about ten times until it is working, I do twice in my code. The upload is 115200 Baud and then stable available. It seems the converter need some time to calculate the fitting speed.
The guy who has written that stuff did get to much money for his job.
Code: Select all
Port geschlossen
Port geöffnet durch Vorgang "javaw.exe" (PID: 1556)
DOWN (0x00000000): IOCTL_SERIAL_SET_QUEUE_SIZE: Set queue size
  InSize=2048
  OutSize=1024
UP (0x00000000): IOCTL_SERIAL_GET_PROPERTIES: Retrieve COM properties
  Packet Size=64
  Packet Version=2
  services implemented=SP_SERIALCOMM
  Max Tx bufsize=0
  Max Rx bufsize=0
  Max baud rate=Changeable bps
  Specific provider type=MODEM
  Capabilities supported=DTRDSR, RLSD, PARITY_CHECK, TOTALTIMEOUTS, INTTIMEOUTS
  Changeable parameters=PARITY, BAUD, DATABITS, STOPBITS, HANDSHAKING, PARITY_CHECK, RLSD
  Allowable baud rates=300 bps, 600 bps, 1200 bps, 2400 bps, 4800 bps, 9600 bps, 19200 bps, 38400 bps, 115200 bps, 57600 bps
  Allowable byte sizes=7, 8
  Stop bits/parity allowed=1 stop bit, None Parity, Odd Parity, Even Parity, Mark Parity, Space Parity
  Tx buffer size=0
  Rx buffer size=16384
UP (0x00000000): IOCTL_SERIAL_GET_BAUD_RATE: Retrieve Baud Rate
  Baud Rate=115200
UP (0x00000000): IOCTL_SERIAL_GET_LINE_CONTROL: Retrieve line control
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
UP (0x00000000): IOCTL_SERIAL_GET_CHARS: Retrieve special characters
  EofChar=0x0
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0x0
  XonChar=0x0
  XoffChar=0x0
UP (0x00000000): IOCTL_SERIAL_GET_HANDFLOW: Retrieve handshake information
  ControlHandShake=0
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  Baud Rate=115200
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x0
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0x0
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=0
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
UP (0x00000000): IOCTL_SERIAL_GET_TIMEOUTS: Retrieve timeouts
  ReadIntervalTimeout=5000
  ReadTotalTimeoutMultiplier=5000
  ReadTotalTimeoutConstant=5000
  WriteTotalTimeoutMultiplier=0
  WriteTotalTimeoutConstant=0
  Baud Rate=115200
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x0
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0x0
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=0
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
DOWN (0x00000000): IOCTL_SERIAL_SET_BAUD_RATE: Set baud rate
  Baud Rate=9600
DOWN (0x00000000): IOCTL_SERIAL_CLR_RTS: Clear RTS
DOWN (0x00000000): IOCTL_SERIAL_SET_DTR: Set DTR
DOWN (0x00000000): IOCTL_SERIAL_SET_LINE_CONTROL: Set line control
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
DOWN (0x00000000): IOCTL_SERIAL_SET_CHARS: Set special characters
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
DOWN (0x00000000): IOCTL_SERIAL_SET_HANDFLOW: Set handshake information
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
DOWN (0x00000000): IOCTL_SERIAL_SET_TIMEOUTS: Set timeouts
  ReadIntervalTimeout=0
  ReadTotalTimeoutMultiplier=0
  ReadTotalTimeoutConstant=0
  Baud Rate=9600
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  Baud Rate=9600
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  Baud Rate=9600
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  Baud Rate=9600
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  ReadIntervalTimeout=4294967295
UP (0x00000000): IOCTL_SERIAL_GET_COMMSTATUS: Retrieve COM status
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  WaitForImmediate=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
UP (0x00000000): IOCTL_SERIAL_GET_MODEMSTATUS: Retrieve modem status
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Baud Rate=9600
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  Baud Rate=9600
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  Baud Rate=9600
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  Baud Rate=9600
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
DOWN (0x00000000): IOCTL_SERIAL_SET_WAIT_MASK: Set current event mask
  WaitMask=RXCHAR: Any Character received
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
DOWN (0x00000000): IOCTL_SERIAL_CLR_DTR: Clear DTR
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
DOWN (0x00000000): IOCTL_SERIAL_SET_RTS: Set RTS
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Modem status=None
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
  Errors=0
  HoldReasons=0
  AmountInInQueue=0
  AmountInOutQueue=0
  EofReceived=FALSE
Port geschlossen
Port geöffnet durch Vorgang "avrdude.exe" (PID: 3904)
  InSize=1024
  OutSize=1024
  Baud Rate=9600
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x4
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0xa
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=1
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  Baud Rate=115200
  WordLength=8
  StopBits=1 stop bit
  Parity=No parity
  EofChar=0x0
  ErrorChar=0x0
  BreakChar=0x0
  EventChar=0x0
  XonChar=0x0
  XoffChar=0x0
  ControlHandShake=0
  FlowReplace=0
  XonLimit=0
  XoffLimit=0
  ReadIntervalTimeout=250
  ReadTotalTimeoutMultiplier=250
  ReadTotalTimeoutConstant=250
 14 10                                             ..
 14 10                                             ..
 14                                                .
 10                                                .
 14                                                .
 03                                                .
 10                                                .
 14                                                .
 03                                                .
 10                                                .
 14                                                .
 10                                                .
 14                                                .
 10                                                .
 14                                                .
 10                                                .
 14 1E 95 0F 10                                    ..•..
 14                                                .
 00                                                .
 10                                                .
 14                                                .
 00                                                .
 10                                                .
 14                                                .
 00                                                .
Will now implement this into the sourcecode.
Postby ericRacer » Wed 30. Jan 2013, 17:34
sirnoname wrote:Yes I know that.
ok, good ! it's a little too much for my knowledge but i understand you make hard work on that !
ericRacer
Images: 36
