maximising wipers using a mechanical trick??
Postby ferslash » Tue 19. Mar 2013, 19:58
Guys i saw day ago the nice design of Scottsim, http://www.x-sim.de/forum/viewtopic.php?t=766
he called "wiper 2DOF for the heavier driver", he introduces an interestig concept the "lever to recuce wiper work" (new to my, maybe it was shown before)
the image Scott uploade was this Image
you can see how the actual weight is lifted by a vertical structure holding a lever...
my question is this: we all know that wipers are grate since they are almost free at a car junk yard, but, on the other side, they have limited life bobbuild told me that he made calculus of around 60 hrs, and... on the other hand when we use wiper to actually hold a sim structure they are not that strong, it come to my mind the florinsky case, he had to buy stronger motors to move his platform... so..
if i use wipers, and consider what Scottsim proposed, but, i enlarge the lever, i should result in
1. less work for the wipers, so larger life?
2. the wiper will use the "lever" effect so it will be able to hold more weight? and maybe be able to move a platform like the one florinsky did?
consider this pic (sorry for my crayola drowing) :D
so... what do you think?
ferslash
Re: Using large lever to reduce wiper work?
Postby prodigy » Tue 19. Mar 2013, 20:26
When you say Florinsky, it sounds like he is a symphony composer :D
Well, for your first question, less work for wiper or easier work is surely better for it and will expand its life.
As for other question, I didn't noticed that project with wipers and levers till now, but it looks interesting though.
Postby yokoyoko » Tue 19. Mar 2013, 20:57
A wiper or any motor can produce some torque [N m].... A newton metre is a unit of torque. One newton-metre is equal to the torque resulting from a force of one newton applied perpendicularly to a moment arm which is one metre long. Like here:
With a lever arm, you can now either increase the force [N] OR the way [m]. In your example in the drawing indeed would the force be higher but you would have little movement on the simulator.
http://en.wikipedia.org/wiki/Lever
.... and the oscar for the funniest guy of the day goes to ... :lol: :lol: :lol:
Postby ferslash » Tue 19. Mar 2013, 21:14
prodigy wrote:When you say Florinsky, it sounds like he is a symphony composer :D
ok, thanks for the imput,,, and yes you are right i mess the name... it is florinske :D sorry about that! :D
ferslash
Postby wptm » Tue 19. Mar 2013, 21:23
Hello Ferslash,
First, thank you pointing this out. I've been watching it for 10 minutes, and trying to figure it out.
What I've found is, that less weight should hold the axis of the wiper. As the handle has a strut. I'm not sure if this the right word, I mean where the handle or lever can turn. I'm sure that this would expand its life.
You're right, that when you larger the lever it can move more at the other end. I cannot calculate what's the best option, for me it'd be an experimentation. ;)
So this is really interesting. The wipers are so weak, it'd be nice if a simple mechanical solution could expand their lifetime and performance.
wptm
Images: 57
Postby ferslash » Tue 19. Mar 2013, 21:28
:lol:
Man thanks for the explanation :D...
so to make the story short... it is recommended... but may reduce sim movement... how can i calculate an intermediate lever size, in order to get the best of two worlds... less motor work, but acceptable movement ??? any idea?
best regards guys
fer
ferslash
Postby yokoyoko » Tue 19. Mar 2013, 21:50
Agree - with such a setup you will not stress the axis of the wiper so much. This is good for a platform setup - not so important for a seatmover. But to place the pivot exact in the center of gravity (of the platform) is also really important, I think.
Have you seen the wiki link? ;)
Or...
sum M(a) =0= -F1*l1 + F2*l2
==> -F1*l1 = F2*l2
l1 and l2 are your leverarms and the radius around point a -> Movement
F1 and F2 are your Forces -> I would take about 6-8 N m for a wiper.
Postby ferslash » Tue 19. Mar 2013, 22:58
wow... i will read deeply the wiki link :D and i think that in that way calculating everithig would be "easy" :D thanks man!
ferslash
Re: maximising wipers using a mechanical trick??
Postby x1610 » Wed 20. Mar 2013, 10:49
it wont do much ,more force means lower speed it,s all in different lever distance
x1610
Postby ferslash » Wed 20. Mar 2013, 17:56
Rob:
Thanks for your replay :( i hate when better means expensive jajaja, but at the end i think i will be using an expensive motor, the thing is that i just kind of finished my sim, it was cheap but looks and feel cheap :D, so insted of improving it, i think that would be better if i do it all again from scratch... that is why i am asking this :(
i think that i will save some money insted :D for a good set of parts
best regards
fer
ferslash
Users browsing this forum: No registered users and 24 guests
