3DOF Sim with Z-rotation
Postby Pitti » Sat 5. Oct 2013, 12:34
Hello
The motion sim from value1 (he was a great help for me) inspired me to design a heli sim with z-rotation. Here we go with a first try but it has much room for improvement.
I'm very interested in what you think, your opinion is desired!
gallery/album.php?album_id=227
Pitti
Re: 3DOF Sim with Z-rotation
Postby value1 » Sat 5. Oct 2013, 14:30
Hi Peter
This looks awesome! It will be fun to fly :) Please be aware that if your axis don't go through the centre of gravity you'll need *very* strong motors. That's the reason why I had to redesign my simulator (see first pictures vs final sim)
value1
Images: 3
Has thanked: 12 times
Postby Pitti » Sat 5. Oct 2013, 14:46
thx! The above-mentioned issue is a fact, the 12/24v worm gear motors are not powerful enough especially if the sim is directly driven. But where there's a will, there's a way...I hope so :)
Pitti
Postby Pitti » Sat 5. Oct 2013, 22:47
Und das Problem mit der Signalübertragung beim 360° Motion Simulator ist mit den Schleifringen auch gelöst:
http://www.ltn.ch/index.php?id=54
Pitti
Postby Riton » Sat 5. Oct 2013, 23:02
I chose Mercotac 3 X 30 A for my Ultimate Machine
Riton
Images: 70
Been thanked: 16 times
Postby Pitti » Sun 6. Oct 2013, 09:02
Riton wrote:I chose Mercotac 3 X 30 A for my Ultimate Machine
Tnx for the tip, that is even better.
Pitti
Postby Pitti » Wed 16. Oct 2013, 12:50
So here we go with a new design. The 360° option is to complicated and also to big. The new solution is my favourite design for *
Pitti
Postby vittobrambi » Wed 16. Oct 2013, 20:40
Hi, for rotation I would recommend only 3 wheels. In that che each wheel is a contact point.
You can have a look to my simulator, that is the solution I chose
http://www.youtube.com/watch?v=MGFHFq1Swpw
Ciao
vittobrambi
Postby Pitti » Wed 16. Oct 2013, 22:08
Nice work! As I wrote above no 360° option for * At least this causes more problems than I can solve.
Pitti
Postby Uryens » Sun 12. Feb 2017, 14:16
Hello,
I would like to build a conceptually similar to the simulator as Pitti.
I have selected three of these AC motors which add a worm gear.
2KW AC Servo Motor Drive CNC Kit 7.7NM 220V 2500R/Min NEMA52 Food Processing - on ebay
But I am a beginner and amateur electrician.
Please advice what interface and a control card should I use in conjunction with x-sim? There are some simple solutions to the existing plugin?
Please any advice. thank you very much
Uryens
