3 dof + 1 rotation software  Topic is solved solved with post #8814
Postby creatorex » Sun 30. Jun 2013, 21:55
http://www.youtube.com/watch?v=U82iHzs2W3Y
İn this sistem which software shold l use,you think? :roll:
ac motor used (asynchronous motor)
creatorex
Re: 3 dof + 1 rotation software
Postby Riton » Sun 30. Jun 2013, 22:19
they use Xsim
Riton
Images: 70
Been thanked: 16 times
Postby creatorex » Sun 30. Jun 2013, 22:38
Why is it necessary to have 3-phase motor
To achieve the same system using two-phase asynchronous motor
creatorex
Postby Riton » Sun 30. Jun 2013, 22:52
you must run the engine in 2 directions.
there is no problem with that, frequency inverters do the work, with a simple normal 220v
Riton
Images: 70
Postby Riton » Sun 30. Jun 2013, 22:54
The single-phase induction motors have characteristics (torque / power density, efficiency, power factor, etc.). Weaker than their counterparts multiphase
Riton
Images: 70
Postby creatorex » Tue 2. Jul 2013, 02:38
Thank you for the informations
creatorex
