Vibrate the brake pedal when wheel's blocking
Re: Vibrate the brake pedal when wheel's blocking
Postby RacingMat » Fri 4. Apr 2014, 20:55
Hi guys!
So, I tried a solenoid as vibrator!
I took one from a steptronic (I'm currently building a DIY sequential shifter) ;)
Here are the results of my tests:
8-)
Postby andpal » Thu 7. Aug 2014, 21:29
Hi, did you get it to work ?
You are by far The most creative person i seen in any simrace forum. It's really greate to following your prosesses in diffrent projects!
I ordered one of those solenoid 12v my self and was hoppening to install this for my self couse the small motors just dont do any "real" effect!
Please tell you succeded :) i want this so bad but can nothing with programing
andpal
Postby RacingMat » Thu 7. Aug 2014, 22:34
Hi andpal!
Thanks for your compliments!
It's working, yes!
it would need probably more tuning but now I'm busy on building a 3 DOF gSeat
I can send the dll to you by email.
yours
Mat
Postby Phsycosocial » Wed 5. Nov 2014, 20:19
Hello, I am very impressed by your work! How is your progress coming along? I am also very interested in setting this up, can you please assist with that is needed to make my brake pedal vibrate.
Thank you,
Phsycosocial
Phsycosocial
Postby RacingMat » Thu 6. Nov 2014, 23:34
@Psychosocial:
I haven't work on this subject since a while... so I decide to share it like it is!
It's working for me (my com port, my relay, ...) and it would probably require a good amount of effort for you to get into it!
but it's better than starting from scratch ;)
I have edited the first post and added the sources, the plugin dll file itself, some explanations
I'll add some more details for better understanding: what I wanted to do and never finished... I hope someone could finalise this (ini file use to setup the inside parameters)...
Yours
Mat
Postby Phsycosocial » Fri 7. Nov 2014, 01:57
Bummer ;(, I do appreciate you sharing your progress so far. I mainly want to have the vibration sensation on my brake pedal. I currently have a buttkicker and have thought about trying to use another buttkicker to somehow connect it to my brake pedal to simulate the brake lockup,
Phsycosocial
Phsycosocial
Postby RacingMat » Fri 7. Nov 2014, 08:14
Buttkicker can be fine as well: just a change in the arduino program to produce buzz sound towards your butt amp.
Postby tiagofmmonteiro » Sun 26. Feb 2017, 15:41
Hi! Great job out there!! I', trying to make a vibrator for brake and gas... But i cannot compile your source code anyway, as the InternalsPluginInfo class and PluginObjectInfo class are nor defined... Maybe it's missing another header file in the source ones? Cannot find a solution for this...
Thanks!
tiagofmmonteiro
Postby RacingMat » Sun 26. Feb 2017, 23:10
Sorry it doesn't work for you
it's too old for me... i changed my computer and do not use Visual anymore, I can't send you anything more
