adding a yaw-movement to a 2DOF-simulator
Re: adding a yaw-movement to a 2DOF-simulator
Postby Mertensbart20 » Thu 10. Jul 2014, 21:56
Hello everybody
Here you can find a new video where I test the simulator with NoLimit Rollercoaster:
https://www.youtube.com/watch?v=dxmY12f ... e=youtu.be
It seems to work well. My job on this forum is done but should anybody have questions I'll gladly help you.
Greetings,
Bart
Mertensbart20
Postby tronicgr » Fri 11. Jul 2014, 02:29
Very Good job!!! Congratulations!
Have you considered using power transfer ring in the base instead of having the power cable tangling over your head? :D
Postby Mertensbart20 » Fri 11. Jul 2014, 09:48
Hello Thanos,
A power transfer ring was also an option. But since the construction is not very accessible at the bottom it would be a real hassle if there would go something wrong with the ring. I will be fitting the powercable with a spring that will keep it more stiff. But even now the cable doesn't bother me when driving.
And an interesting point for you, it all started the three years ago with your 2DOF design (the construction with the PVC-tubes). So thanks for the inspiration!
Bart
Mertensbart20
Users browsing this forum: No registered users and 23 guests
