Motion simulator 2DOF (wiper motor)
Postby stephaned61 » Sun 2. Dec 2012, 12:41
hello,
this is my homemade cockpit.
The motion simulator is constructed on the basis of the combination Velleman VM110(K8055) + Sabertooth 2x25A + wiper motor.
Here is a video presentation and demonstration of my cockpit (in French)
A tutorial on building my simulator is visible on my forum: http://vos-playseat-stephaned61.xooit.fr/t7-Creation-d-un-simulateur-automobile-2DOF-avec-des-moteurs-d-essuie-glace.htm
stephaned61
Re: Motion simulator 2DOF (wiper motor)
Postby motiondave » Sun 2. Dec 2012, 13:11
nice job there, well done.
Just a suggestion, if you ever plan to get bigger motors, i suggest these http://www.motiondynamics.com.au/worm-d ... -180w.html , they will make you really stand up and notice.
But otherwise said, great job.
Postby vicpopo » Sun 2. Dec 2012, 13:31
Salut,
Nice to see you in this forum.I 'm happy seeing the french team here !!!
As I often said in this forum your job had a lot inspired me for building simulator.
Many Thanks and your simulator is always awesome!!
Best Regards
Postby stephaned61 » Sun 2. Dec 2012, 13:52
motiondave wrote:nice job there, well done.
Your engines seem to be interresting. They are equipped with potentiometers?
vicpopo wrote:Salut,
Best Regards
stephaned61
Postby motiondave » Sun 2. Dec 2012, 14:02
I had to put pots on the motor via a lever system
something like this.
I use JRKS though.
Now thanks to some left over gears off a winch motor I use multiturns
Floriske runs a similar motor on his sim. They are fast and powerful.
As said, just a suggestion....
Postby stephaned61 » Sun 2. Dec 2012, 14:21
Ok!
My potentiometers are installed in this way:
stephaned61
Postby zecaEU01 » Sun 2. Dec 2012, 20:39
Good Afternoon stephaned61.
You installed the gears higher and lower motor potentiometer in which the difference in the ratio of 1:1.
zeca
stephaned61 wrote:Ok!
zecaEU01
Postby Poonaam » Fri 24. Jan 2020, 08:27
Hi!
Excellent share!
Thank you!
Poonaam
