Token System (İnsert Coin)
Postby Sadex » Mon 24. Sep 2018, 18:07
I want to add the coin system to the 2dof simulation. In addition; Can you tell me about the car races that are compatible with the credit(s) system. Can you help me with this?
this is
Sadex
Re: Token System (İnsert Coin)
Postby multitronix » Thu 19. Sep 2019, 05:48
Hello, if they are not arcade versions there is no compatibility with tokens, however there is always a solution, such as this timer designed especially for the use you need, if you want to convert your simulator to an arcade machine, which receives tokens
You can program with how many tokens a game starts, accumulate time if they insert more tokens, manage their own rates, indication of time to finish, time finished, etc., the LCD visualization allows you to send a lot of information on the screen, with this device you can control your engines , your controls, since it also controls a usb port, you can enable and disable the use of the token simulator, as programmed.
4767
multitronix
Users browsing this forum: No registered users and 21 guests
