A new "diferent" 2dof Sim...
Postby ClubvueloUPM » Fri 6. Apr 2018, 13:24
Hello everyone, first of all, we are a group of Aeronautical engineering students and soaring enthusiasts from the Polytechnic University of Madrid (UPM)
Some moths ago , in our base aerodrome we were asked if we want a crashed glider ,a Grob Astir CS, to make a flight simulator,
In this state was the aircraft when we opened the door:
4580
After some weeks of fiber and painting works:
4583
And the last one, finished, we used the original rudder and airbrake controls and 2 100K pots to transform the signal into a digital one received by an usb motherboard (Leo Bodnar).
4582
With all finished, we began to study if we could make a 2 dof simulator with the cabin, nowadays we want to use 2 wiper motors from a truck, but apart from that we don`t know a lot more, we have read some tutorials but this is a big proyect, so we need more help.
So here we are, looking for some advices to achieve a good result with this.
Best Regards
ClubvueloUPM
Re: A new "diferent" 2dof Sim...
Postby ClubvueloUPM » Fri 2. Nov 2018, 16:27
The poject continues and we have the motors working, however we have a problem with the X-sim and the free condor instruments http://condorsoaring.ru/projects/FreeCo ... dme_en.php, both use the 55278 port , and they cant be working together, as we try it, a error message appears.
Is there any solution? thanks
ClubvueloUPM
Postby sirnoname » Fri 2. Nov 2018, 16:53
Is it possible to enter two PC's or a second app?
Postby ClubvueloUPM » Mon 12. Nov 2018, 20:32
Problem solved, Condor free instruments has the option to redirect the udp data to another port, so we simply set the 55277 port on the udp ini, and using the instruments default.ini redirect the traffic to the default 55278.
ClubvueloUPM
Postby ClubvueloUPM » Wed 20. Feb 2019, 21:05
Hello!
We have a problem using the extractor, it shows an error saying error on the support channel, begins to search for the servers and nothing happens.
ClubvueloUPM
