Postby dearn » Fri 14. Sep 2012, 16:02
Hi all!
FINISHED: PAGE 8
3133
I wanted to show my first project here, it will be 2DOF with 2 big motors (from Floriske :D ) driven by 2 Pololu's 12V12 and offcourse X-Sim. :)
I'm a beginner in the sim world, so i'm very happy to see this forum with projects and people to help me out. Also a few parts of my sim will be provided by my webshop http://www.ArcadeWinkel.nl. (sorry for spamming :oops: )
Here are some pic's first, later on i will add more information, pictures and so on. If you guys have any idea how to make things better in functionality or design, please post it here!
Grtz,
Arno
It all started when i got an old racing sparco seat from a friend and bought an old BMW driveshaft:
270
Then the package from Floriske was coming in:
271
Nice big motors with a 1:25 gearbox:
272
Time for buying metal for the frame:
273
Positioning the center for the pivot:
274
Drilling and so on:
275
276
It fits :D
277
278
I'm not so good with welding because it's a cheap electrode machine, hope it holds
279
Finally, the pivot:
280
Then the old seat, it needs a mounting, so i made one. It will be mounted on wood.
281
The seat will be covered with new red and black fabric after a while
282
New parts arrived! 8-)
Rod-ends
283
2nd hand 23" monitor.
284
Yeah, a brand new G27 :mrgreen:
285
PSU's and springs that are well known on this forum.
286
287
I'm making a custom motor mounting system from wood and metal, starting with the metal brackets:
288
289
This new mounting system holds the motor up so all the weight of the motor itself will be off the gearbox:
290
291
292
Allmost finished:
293
294
295
This will be it for now!
Grtz,
Arno
dearn
Images: 139
Re: 2DOF Race Simulator - Sponsored by ArcadeWinkel.nl
Postby floriske » Fri 14. Sep 2012, 16:11
Finally there it is! :D
[s]Really looking forward to seeing your progress![/s]
Edit: That's quick ;) Looking good so far!
floriske
Images: 96
Postby dearn » Fri 14. Sep 2012, 16:21
Thank you Floris!
The sim frame is allmost finished at this moment, i just have to find time to make the topic ready haha.
My pic's are a bit "zoomed", how can i fix this?
Tnxs,
Arno
dearn
Images: 139
Postby floriske » Fri 14. Sep 2012, 16:26
I would advise you to use your personal gallery you have on this forum:
Here's a short tutorial: viewtopic.php?f=3&t=162
This way you don't have to use external hosting, pics won't get lost over time, are easy to implement and can simply be linked to on external sites.
floriske
Images: 96
Postby dearn » Fri 14. Sep 2012, 16:29
floriske wrote:I would advise you to use your personal gallery you have on this forum:
Here's a short tutorial: http://x-sim.de/forum/viewtopic.php?f=3&t=162
Tnxs, that's a nice feature.
dearn
Images: 139
Re: 2DOF Race Simulator by Arno
Postby motiondave » Sat 15. Sep 2012, 01:32
Nice job there, welding looks good, better than mine.
Nice idea about the mount for the back of the motors. That would make them steady. But it wont really take any load off the gearbox.
Good to see progress. The big motors will give you some BOOT for sure!
Postby dearn » Sat 15. Sep 2012, 21:24
motiondave wrote:Nice job there, welding looks good, better than mine.
Hi motiondave,
Tnxs for your reaction! I hope that the motors will be good enough :D. I enjoyed reading you topics btw ;)
Tomorrow there will be a big update in my post!
Grtz,
Arno
dearn
Images: 139
Postby motiondave » Sun 16. Sep 2012, 00:49
Hi motiondave,
Grtz,
Arno
Floriske can advise on the motors as he has these. I use similar ones , but not bought off ebay. I believe they will still do damage though! Considering I used several different types of wiper motors in the past , and all with good results.
Postby dearn » Sun 16. Sep 2012, 23:38
Frame update! :D
I'm using steel square tubes for my frame that will holds te wheel and pedals. This frame will be mounted on wood later, with the option to mount it in 2 positions, close or far away from the race seat.
296
297
298
299
300
301
The feedback pots arrived, these are "high quality" 5K pots, 10K normal pots are on there way from China at the moment. I think i will use the 5k at first.
302
For stability the frame needs a support under the wheel:
303
304
305
The frame isn't done yet, next step is to weld a pedal mounting and start to build a small frame for the G27 shifter.
306
307
308
Do you guys like the simple design?
dearn
Images: 139
Re: 2DOF Wormgear Race Simulator by Arno
Postby floriske » Mon 17. Sep 2012, 08:46
Looking good!
Just make sure your balance point is spot on when you are done (determine it with the most frequent driver in the chair of course ;)).
One thing i would do if it's your intention to have multiple people racing on it: make your pedals easilly adjustable. Something I noticed with mine with 3 different people: the steering wheel could stay in it's place, the pedals had to be move for each one of them!
KUTGW!
p.s.I've made quite good progress with setting up the motors (thanks Bob for all your tips!) but because we are currently finishing the construction work of the sliding doors on our attic (where the sim is standing) and are sorting out all the stuff that has to go behind them ;) I have to postpone the testing for a short while.
floriske
Images: 96
Users browsing this forum: No registered users and 52 guests
