2dof sim code
2dof sim code
Postby volkantopc » Mon 29. May 2017, 20:05
Arduino code for dynamic playseat 2DOF
#define BRAKEVCC 0
#define RV 2 //beware it's depending on your hardware wiring
#define FW 1 //beware it's depending on your hardware wiring
#define STOP 0
#define BRAKEGND 3
#define pwmMax 255 // or less, if you want to lower the maximum motor's speed
// defining the range of potentiometer's rotation
const int potMini=208;
const int potMaxi=815;
#define motLeft 0
#define motRight 1
#define potL A0
#define potR A1
// DECLARATIONS
/* VNH2SP30 pin definitions*/
int inApin[2] = {
7, 4}; // INA: Clockwise input
int inBpin[2] = {
int pwmpin[2] = {
5, 6}; // PWM input
int cspin[2] = {
int enpin[2] = {
int statpin = 13; //not explained by Sparkfun
/* init position value*/
// INITIALIZATION
void setup()
// serial initialization
Serial.begin(115200);
// initialization of Arduino's pins
pinMode(statpin, OUTPUT); //not explained by Sparkfun
digitalWrite(statpin, LOW);
for (int i=0; i<2; i++)
pinMode(inApin[i], OUTPUT);
pinMode(inBpin[i], OUTPUT);
pinMode(pwmpin[i], OUTPUT);
digitalWrite(inApin[i], LOW);
digitalWrite(inBpin[i], LOW);
///////////////////////////////// Main Loop ////////////////////////////////////
void loop()
int sensorL,sensorR;
readSerialData(); // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
// the previous order will still be used by the PID regulation MotorMotion Function
sensorR = analogRead(potR); // range 0-1024
sensorL = analogRead(potL); // range 0-1024
void readSerialData()
byte Data[3]={
'0','0','0' };
// keep this function short, because the loop has to be short to keep the control over the motors
if (Serial.available()>2){
//parse the buffer : test if the byte is the first of the order "R"
Data[0]=Serial.read();
volkantopc
Re: my 2DOF motion simulator, ardunio, motomonster
Postby lucioviper » Tue 20. Jun 2017, 03:49
very nice. im building my 2dof like yours buyt im have some troubles with pots...
How did you connect your potentiometers to the motors?
lucioviper
Postby Bora » Thu 22. Jun 2017, 22:51
You can use couplings. It's very useful for connect different diameters of shafts.
Bora
Images: 12
