Pneumatic 6DOF
Pneumatic 6DOF
Postby Zoszko » Sat 24. Oct 2015, 11:54
Hey Fellow SimRacers,
I am working on a similar project like misterfarmer's except it's bigger. I am using 500mm reinforced cylinders with servo valves a flow controller for each of these valves.
I know it's gonna be huge, but I like the idea of it being huge.
I was looking at various builds here, but I could not find any data on how should I place the cylinder expect the fact that the group of cylinders are 120 degrees form each other and the top frame is rotated by 60 degrees.
How do I calculate the diameter of the mounting points and the distance between the platforms?
billo2404 have posted some pictures with actual dimensions on DoctorD's thread, but not actual formulas.
Please help!
~Zoszko
Zoszko
Re: Pneumatic 6DOF
Postby misterfarmer » Sat 24. Oct 2015, 13:02
Hello zoszko,
I could not find any information about sizes etc also. so i started watching images on google. After that i decided to make to excactly the same triangles.
after some testing things in sketchup, i decided to do it the most tricky way, so i started to make 6 excactly the same plates where the cilinders wil be connected. after that i mounted everything. so al the cylinders where connected. I was wondered because i could excactly make a triangle with it on the ground. so i thought when i measure the size between attachment points with cylinders in and make that the distance between the attachment points.
i don't know if it is excactly alright but it worked for me, everything is moving (except yaw is doing strange to one side).
Mayby it's the wrong choice i made but it will help you a little bit.
Greets
misterfarmer
Images: 18
Re: Pneumatic 6DOF
Postby misterfarmer » Sun 25. Oct 2015, 20:38
Hi!
When considering my decisions I think I made a small mistake. I need to make the platform a little bit bigger. Because when the cylinder is in the middle.
The angle of the platform needs to be 60 degrees. I measured the length with the cylinder in. I think this will give the problems with the yaw on my platform.
I hope I can try this next weekend.
Greets
misterfarmer
Images: 18
Re: Pneumatic 6DOF
Postby Zoszko » Mon 26. Oct 2015, 00:25
Well I have been working on this yeasterday and figured out the right dimensions. It's going to work, there is no collision.
In the mean time I have spent some time working on my code, however misterfarmer sent me his code (twice, thanks mate!), but I have made mine so I know my way around it.
Here's a short video where you can see the lenght of each cylinder:
Zoszko
Re: Pneumatic 6DOF
Postby Zoszko » Sun 20. Dec 2015, 21:27
Working now!
My friend is driving in rFactor here:
Zoszko
Re: Pneumatic 6DOF
Postby misterfarmer » Mon 21. Dec 2015, 14:57
it's very nice to see this working..
misterfarmer
Images: 18
