Simulator 2DOF Velleman+Sabertooth 2x25
Postby misterk » Mon 5. Jan 2015, 01:59
3533
Hello everyone, I would like to share with you the realization of my project that consists of a motion platform 2dof which will then be converted into 3DOF.
Starting material:
Seat with metal structure
3517
Logitech G27
3 Monitors 27 "
For the platform:
2 wiper motors
velleman K8055
sabertooth 2x12
2 potentiometers
12v power supply 50A
550w ATX power supply for PC
All mounted and tested movement with two pallets before making the final structure:
3519
3520
Until everything is right, the realization of the mobile platform.
First of all I have recovered a drive shaft of a panda from which I derived a universal joint.
3521
From here then I changed my path because I recovered a base already partially built, and come equipped with:
3522
Now a thousand tests to look for it and set the electronic x-sim.
First Issue, engines too weak to move properly the platform, new engines !!
3523
Made supporting structure for engines:
3524
3528
3529
Changes in the structure to accommodate the new engines:
3525
3526
3527
Unfortunately the sabertooth 2x12 was not powerful enough for these engines, turned slow.
Sabertooth replaced with version 2x25.
First phase completed !.
Decided to resume the structure, rebuilt entirely of aluminum.
In this way it was possible to make adjustments and settings in a much simpler without continuous welds!
3531
Problem of instability in the front part, fixed with a Teflon bar that slides into a support preventing the structure from moving laterally.
3532
3534
Structure finished:
3533
The first results are there but not there yet:
https://www.youtube.com/watch?v=EMjY7uZ_cqA
... finish for now
misterk
Images: 18
Re: Simulator 2DOF Velleman+Sabertooth 2x25
Postby kevin123 » Tue 13. Jan 2015, 19:20
Ottimo lavoro misterk!! Complimenti ;)
Great job !! misterk congratulations ;)
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby vicpopo » Wed 14. Jan 2015, 08:16
Hi misterk,
Nice project , very well done .Congratulations
Users browsing this forum: No registered users and 27 guests
