6 dof Flight & Racing Sim Build Log
Postby telfel » Sun 2. Mar 2014, 20:19
Sketch of proposed 6 dof motion platform.
2595
Component Specs
6 x 24 volt, 590 watt, DC motors with 25/1 worm gearbox
3 x Sabertooth 2x60 motor drivers with Kangaroo x2 Motion Control Modules
1 x USB/TTL Converter
6 x Hall Effect 180 deg Pots mounted on the back of the gearbox output shaft
12 x V3 Limit Micro Switches operated by cams on the back of the gearbox shaft
12 x M12 Rose Joints (Heim)
12 x M8 to M12 High Dispacement Angle Spacers
6 x M12 Stud for pushrods
3 x Base made from 1m x 150mm x 50mm Timber
Top Platform 20mm High Density Plywood, seat bolted direct to platform. (dims to be determined)
2 x Aluminium U channels 75mm x 40mm to protrude forward to mount controls & pedals
CastAR HMD Glasses with retro reflective 180 deg wrap around screen.
3.2Ghz XP PC to run Converter
New Gaming PC (details to follow)
regards Terry
telfel
Images: 54
Been thanked: 9 times
