Simulator model Kevin :)
Postby juah » Sat 2. Nov 2013, 20:32
Hello friends I present to you my new simulator :-) as you will see very similar (equal) to the simulator built by Kevin and I thank him already 'now for all the material on line
2279
juah
Images: 12
Re: Simulator model Kevin :)
Postby prodigy » Sat 2. Nov 2013, 21:33
Nice setup, dual combo. One for you, one for your co-driver Kevin :)
Postby sirnoname » Sun 3. Nov 2013, 00:49
Mass production :)
Do you offer the drawings for a rebuild?
We need some good tuts and devices in mass production are a good idea ...
Postby juah » Sun 3. Nov 2013, 01:05
sirnoname wrote:Mass production :)
The material that I have I can make available
juah
Images: 12
Postby juah » Sun 3. Nov 2013, 01:54
227522742273
juah
Images: 12
Postby juah » Sun 3. Nov 2013, 01:58
2276
juah
Images: 12
Postby juah » Sun 3. Nov 2013, 20:21
2282
Hello guys, before continuing with the development of the simulator if I tried tabs and motors work, I followed the great tutorial by Kevin and I also read a little 'manual I downloaded the profiles for compendium of games, but nothing :-( help me, the problem is that when I launch the game (I've tried many) eg no Limit Simulator engines begin to run or stand still but do not follow the trend of the game
Ciao ragazzi , prima di proseguire con lo sviluppo del simulatore ho provato se le schede e i motori funzionano , ho seguito il fantastico tutorial di Kevin e anche ho letto un po' il manuale ho scaricato i profili per igiochi , ma niente :-( aiuto per me , il problema che quando lancio il gioco (ne ho provati molti ) es No Limit Simulator i motori cominciano a girare oppure stanno fermi ma non seguono l'andamento del gioco
juah
Images: 12
Postby juah » Thu 7. Nov 2013, 19:29
Hello it's me again, tell me if anyone would know to operate No Limit X-SIM Simulator serves a fee or is there 'some other system? I can not find the plug-in with a good evening
Ciao sono ancora io , qualcuno saprebbe dirmi se per far funzionare No Limit Simulator serve x-sim a pagamento o c'e' qualche altro sistema ? Non riesco a trovare il plug-in grazie buona serata
juah
Images: 12
Postby juah » Sun 10. Nov 2013, 23:24
Upgrade !!!!! :D :D
229022872289
juah
Images: 12
Postby billo2404 » Sun 15. Dec 2013, 04:53
juah wrote:2282
Ciao, ho lo stesso identico problema sul mio sim, tu hai risolto???
eventualmente possiamo avviare una collaborazione, io credo ci sia qualche errore o omissione nella programmazione di x-sim.
billo2404
Images: 72
Has thanked: 7 times
Users browsing this forum: No registered users and 40 guests
