Ultimate MSXR 3/4DOF
Re: Ultimate MSXR 3/4DOF
Postby Riton » Tue 22. Jul 2014, 11:39
little news, 2 new motors, one for the 3 rd axis, and one for 360 ° rotation.
I'll make cams, soon the first tests.
Riton
Images: 70
Been thanked: 16 times
Postby Riton » Wed 6. Aug 2014, 19:18
2 short videos of the development.
I'll have to make small modification.
I missed an important point on the wooden model.
moving on my shaft translation was not symmetrical.
it is now set to the 2 nd video
Riton
Images: 70
Postby Riton » Mon 18. Aug 2014, 15:53
model of my new support potentiometer.
until now I have neglected this support, it is the opportunity to work and lead this new potentiometer support
the final part will be made of aluminum
Riton
Images: 70
Postby scottlolo » Mon 18. Aug 2014, 21:58
good work :shock:
scottlolo
Images: 5
Postby Riton » Sun 24. Aug 2014, 15:48
First test, first problem...
Bad news today ...
I plugged my new and very unfortunately it lacks torque motor 30.
I have not checked the settings and tuning of the drive, but it seems to compromise.
some times when I go fast on the sim, this puts the engine to do a strange noise and it becomes "soft" without being able to hold a charge.
the display shows 5 A out.
Riton
Images: 70
Postby Riton » Tue 26. Aug 2014, 00:38
second test:
engine power is a bit small
but I mishandled the engine!
I weigh 88 kg, I jumped and abused the engine by putting my weight on the cylinder as close to the cylinder.
I can do unhook
torque motor
I need to finish the frame to really test properly in games.
I am confident.
I have some solution if I run out of power:
put a spring, reducing the cam.
[YouTube]https://www.youtube.com/watch?v=vZIrxC-cD5o&list=UUyGsvEW6uOyxJdvJIOVIsMg[/YouTube]
Riton
Images: 70
Postby tronicgr » Tue 26. Aug 2014, 00:54
Hi Richard,
Where is that shaking is coming from? Which AMC do you have now (remind me) is the older one AMC644USB?
Can you turn off the LCD updates while trying with the motor? It will make the responce of the PID much better.
I haven't updated the firmware of the AMC644USB since long time as I was busy integrating new features on the AMC1280USB...
I hope to have some parts delivered soon so I can send you your new controller.
Regarding the spring solution... Maybe add a complete car suspension system... it will damp as well :)
Postby Riton » Tue 26. Aug 2014, 10:07
HI Thanos
yes, that's my old card AMC 64. ;) just to test the motor
actually, I find it hard to adjust the PID
In addition, the encoder function setting is malfunctioning, when I turn it jumps functions may be you can add me in sending the new AMC 128.
but I'll get to tame the monster !! :)
Riton
Images: 70
Postby Riton » Wed 27. Aug 2014, 19:10
2 Motors left 16 RPM, right 31 RPM
PID is Bad .
Riton
Images: 70
Postby tronicgr » Wed 27. Aug 2014, 20:15
Here some suggestions:
-Decrease the Motor max speed on the AMC644USB LCD menu. Maybe down to 50%
-Set PID to 3,1,1
-Disable the LCD updates (dip switch)
-Decrease the max motor RPM via the VFD configuration, to half of the rated speed of the motor.
Also check the cables from the sensors to see if they go near power cables causing interference. Ground the shield of the sensor cables if possible.
In the new AMC1280USB I've added oversampling on the sensors to filter noise better.
