thecure wrote:I've a problem with rfactor, for example, when I crash into the wall or the guardrail the motor's rotation drastically ralentate and then when I come back in the circuit the problem does not solve. Is there any parameter to fill in x-sim?Thank you
Arno wrote:Hello there,
Any progress on the actuators?
I am starting a very similar project and was hesitating between using gearboxed motors, or linear actuators like you were thinking.
Thank you.
Arno
motiondave wrote:He would need powerful actuators, unless he makes a spring underneath. I got my hands on some actuators that are ETH series ,
ET050B05MA000A00FMDH0100A but I use 12v motors, if you can find them cheaper than $2700 each, these would be the go for sure. Mine move 40kg at 300mm per second with 12v motors viewtopic.php?t=605
SCN6 may do but they are costly as well.
Racerr87 wrote:Looking really good!
What speed are you trying to get for the actuator?
And what speed would be sufficient?
I found some Chinese ballscrews maybe this is something for you:
(I don't know much mm motion there is in 1 revolution?)
http://www.ebay.com/itm/3-anti-backlash ... 3a7b323ab8
