3DOF power simulator
Re: 3DOF power simulator
Postby Turn » Sun 14. Oct 2012, 18:55
Hey guys - how did you just appear out of nowhere with results like that!? :) Amazing!
Congratulations. I look forward to seeing your final electric actuator results. I'm sure they'll be great.
Turn
Postby thecure » Mon 15. Oct 2012, 12:49
tks !! :D fingers crossed ;)
thecure
Been thanked: 5 times
Postby thecure » Mon 15. Oct 2012, 20:03
The first circuit
thecure
Postby thecure » Thu 18. Oct 2012, 15:36
I finished the first circuit :D .......I have to buy the last resistor near led
thecure
Postby thecure » Sat 20. Oct 2012, 18:12
I finished the speedy's h-bridge, but does not work .. the only thing that I tried is measuring the voltage on 7805, but I haven't it.....what kind of measures can I try? tks
another question .... I do not have the gnd continuity's . It's correct
thecure
Postby thecure » Mon 22. Oct 2012, 11:08
I tried with this circuit .... I connected in this mode but does not work..possible solution
thecure
Postby tronicgr » Mon 22. Oct 2012, 19:24
Umm... what motor driver is this? Do you have a link to its datasheet??
It has two PWM inputs and one DIR !!?? Hmm...
Postby thecure » Mon 22. Oct 2012, 20:38
thecure
Postby tronicgr » Mon 22. Oct 2012, 21:32
There are two ground pins on this motor driver, both must be connected on the amc GND pin... You forgot to connect one of them ;)
Postby thecure » Mon 22. Oct 2012, 22:19
it's a different gnd ?...because i have tested with a tester it's the same gnd
thecure
