Postby titofe » Sun 3. May 2020, 16:07
bonjour je suis nouveau.j'ai construit mon propre simulateur de 2dof avec le moteur essuie-glace arrière et.Je suivi un petit peu les conseils que j'ai vu sur le forum j'ai mis le code arduino racing mat j'ai une carte Monster.M,j'ai un des moteurs qui marche avec les pot. en avant en arrière à la main,l'autre moteur il bouge que dans un sens,.dans x.sim j'ai configuré,qu'on me demande dans les forums il y a rien qui bouge,quelqu'un dans le forum qui pourra m'aider c'est gentil de leur part avec,configuration de débutant,merci d'avance les amis....;):):sos
titofe
Postby RacingMat » Wed 6. May 2020, 14:38
try swapping motors with Hbridge output,
then try swaping potentiometer ... to determine where is the problem.
something is probably badly wired?
post some pictures
Postby flotis » Tue 19. May 2020, 10:51
Hi. I have made the simulator 2 dof. (Arduino, Monster, 12V windscreen wiper motor, 10k potentiometer). I need if you can and you don't care if you help me. I have followed the manual step by step, and I think I have a problem with the potentiometers. The motors should stop when the potentiometer is in the middle, and turn to one side or the other depending on where we turn the potentiometer, but my potentiometer does not stop in the middle, it has much more travel to one side than to the other and when I do the tests entering the codes to make the movements does not do it correctly. Can you tell me why? What can be the solution?
flotis
Postby SaleU1983 » Wed 17. Jun 2020, 18:38
Wow, I'm new to this and I'll try to do something similar, this simulator especially fascinated me for the detailed instructions. Nice and tnx! :D
SaleU1983
Has thanked: 5 times
Wow, I'm new to this and I'll try to do something similar, this simulator especially fascinated me for the detailed instructions. (I am currently collecting parts and material) Nice and tnx !!!!! :D
SaleU1983
Postby HIRO » Fri 16. Oct 2020, 03:03
Thx!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :D
HIRO
Postby RacingMat » Sun 11. Apr 2021, 17:06
Sent: 02 Nov 2020, 11:14
by @Sametburak
Hi I've set up your project but I'm testing the engine does not map in the game causes it to work outside
Hi!
please describe what steps worked fine: without pot, with pot, with serial monitor, with game...
look for "first hardware tests and trials" in the first post ;)
Postby RemcoF » Sun 2. May 2021, 14:42
kalarius wrote:yes
I make my setting and I have place at the attachment file
rename the file to rn2 because the site does not allow to aupload the rn2 extension So I rename it to .txt
I have use this file at my first simulator See then video at http://www.kalarakis.com/html/rali.html
this helped me a lot to sort out the needed math components, I tried to make it first by myself but that did not work...
with your math settings I only needed to invert the output and changed left to right and now the sim works.
thanks a lot :D
RemcoF
Postby RacingMat » Mon 3. May 2021, 10:43
good news :)
congrats!
would you mind to share a vid in action? via https://streamable.com/upload-video you don't need any account
