Raceflight V2
Re: Raceflight V2
Postby Bruceaust » Thu 13. Sep 2012, 23:52
Zandvoort and Brands Hatch are fantastic for testing sim motion! Sim still going strong without a glitch. Although I think I will need to invest is some higher quality feedback pots or work out some method of using hall effect sensors in multi turn mode. I need to measure about 3 turns, end to end, on both axis.
Bruceaust
Re: Raceflight V2
Postby Bruceaust » Fri 14. Sep 2012, 12:11
At present I am using those inexpensive 5turn pot as shown in this thread. They work Ok but I have already replaced one because it was noisy around "centre".
I reckon they will give me problems in the near future. I have seen those pot from RS: expensive but they will no doubt last a while. I an doing some research into Hall Effect "pots". They might be worth playing around with, but it will require some gearing to get them to work for me.
No I havn't tried "Dirt" or R factor I have been iracing for a couple of years, so I am more or less committed to that. I am also building an F16 flight sim which I intend to motionisze (new word? :D ) At this stage I intend to use only 1 axis on that sim.
Bruceaust
Re: Raceflight V2
Postby motiondave » Fri 14. Sep 2012, 12:18
Dirt 2 China trailblazer, teeth rattler for sure! Not to mention wicked lateral, longitudinal, and pitch.
Re: Raceflight V2
Postby floriske » Fri 14. Sep 2012, 13:39
@Bruceaust: Don't forget to send me your PC code in order to receive your stage 2 key ;)
floriske
Images: 96
Re: Raceflight V2
Postby yokoyoko » Fri 14. Sep 2012, 15:07
Hi Bruce,
another good quality for the price pot in my opinion http://www.leobodnar.com/shop/index.php?main_page=product_info&cPath=81&products_id=194 for suggestion.
same here. My solution was to reduce the tooth flank clearance of the gears. (I hope this is the correct translation german=Zahnflankenspiel)
I use gears with "modul 1" (~like pitch 32dp, I think) - to adjust tooth flank clearance I use now a thin piece of plastic bag between the gears. Press the gears together and tighten the screws. If you remove the plastic the clearance is not to big (noisy) and not to small (binding).
