Postby RacingMat » Thu 10. Jul 2014, 21:55
Thanks hc26!
yes, the code is compatible: arduino UNO and DUE!
good luck for your project :)
Let us know your progress
yours
Mat
Postby wallytattoo » Fri 25. Jul 2014, 15:33
Hi all, someone would be so kind to pass me the profile of x-sim.
I can not configure it, there are some settings that I do not notice.
I would be grateful and try my arduino code.
A greeting
wallytattoo
Has thanked: 5 times
Postby pipis2014 » Fri 25. Jul 2014, 18:55
wallytattoo wrote:Hi all, someone would be so kind to pass me the profile of x-sim.
A greeting
have a look here:
viewtopic.php?f=37&t=943&start=150#p12133
pipis2014
Images: 105
Been thanked: 5 times
Postby profetadelmus » Sat 26. Jul 2014, 11:05
A greeting
remeber that you can load online shared profiles of other users in extractor!
profetadelmus
Images: 32
Has thanked: 10 times
Postby wallytattoo » Wed 30. Jul 2014, 15:56
Thank you very much for the replies.
Now I have another question about the Arduino code, and I do not understand much because I started using recently.
that part of the code defines the arduino pin, I think it is
Code: Select all
  inApin int [2] = {
   7, 4}; / / INA Clockwise input
inBpin int [2] = {
   8, 9}; / / INB: Counter-clockwise input
pwmpin int [2] = {
   5, 6}; / / PWM input
cspin int [2] = {
   2, 3}; / / CS: Current sense input ANALOG
enpin int [2] = {
   0, 1}; / / EN: Status of output switches (Analog pin)
I do not understand what you mean is what is in brackets {7, 4};
I assign to the inApin pin 2 is variable and {7, 4}; or as I interpret this to know what are the pins.
a greeting
wallytattoo
Postby RacingMat » Wed 30. Jul 2014, 17:53
Hi!
It's an array to store 2 values.
Mat
Postby mosky2014 » Wed 13. Aug 2014, 12:46
RacinMat
Thanks for share all this detailed project.
I started my project ( Sorry I will follow all your steps) to build my 2 DOF.
I'm trying to get all the build material
I have 2 wiper motors (not used), 3 arduino R3,
I'm waiting for my motor driver shield ( bought DX )
Next weekend I'll start with the chasis.
Thanks again to share and support us.
mosky2014
Postby RacingMat » Sat 16. Aug 2014, 11:10
Hi Mosky2014!
You're welcome!
Following the steps is good! it will hopefully spare you some errors and trials...
About the wiper motors, I would strongly advice you to order NIDEC SMolka!
if not, check that the ground is isolated from outer body! and that they are almost irreversible!
yours
Mat
Postby gingercat » Wed 3. Sep 2014, 21:18
There's a bug in the source code in the first post, the hex to decimal conversion doesn't take into account that 'A' has a value of 10, and the conversion will be setting it to 0:
Code: Select all
if (x[i]>47 && x[i]<58 ){//for xA to xF
should be
Code: Select all
if (x[i]>47 && x[i]<58 ){//for x0 to x9
then
Code: Select all
if (x[i]>64 && x[i]<71 ){//for x0 to x9
      x[i]=x[i]-65;
should be
Code: Select all
if (x[i]>64 && x[i]<71 ){//for xA to xF
      x[i]=10 + (x[i]-65);
Should add - thanks for the code!
gingercat
Postby RacingMat » Thu 4. Sep 2014, 09:22
Thanks Gingercat for reading carefully the code!
Yes, the comments are swaped! I have to correct this!
but I have to think about your +10
Have you started building a sim?
__________________
Edit: yes, you're right! 8-)
my mistake I did recently when I made a change in the post
-65 should be -55 in order to convert "A" into "10"
Users browsing this forum: No registered users and 48 guests
