Postby RacingMat » Tue 3. Jun 2014, 10:25
Hi Pmstick!
I'm glad that you find the tutorial useful :) and I hope to see you driving soon!
Yes, it's welded on both sides.
But if you don't like this way, you can use bolts:
2932
yours
Mat
Postby Pmstick » Tue 3. Jun 2014, 16:18
Thanks Mat, that is a good idea, I reckon I can make that work. It will be much easier getting it up my stairs if I can carry it in a couple of pieces.
I have build the top part and I am loving using it with no motion on my just signed up for iracing account. Now I just need to stop racing long enough to complete the lower frame.
Sent from my iPad using Tapatalk
Pmstick
Postby seanbig » Sat 5. Jul 2014, 10:08
Hi, Mat
I want add springs in four corner to maintain the seat position and angle before I hop in the cockpit. Could you suggest me what type springs can hold around 25kg each corner.
Thanks, Sean
seanbig
Postby RacingMat » Sat 5. Jul 2014, 11:10
seanbig wrote:to maintain the seat position and angle before I hop in the cockpit
no, the springs won't maintain the position... if they were strong enough to maintain the position under your weight, the motors won't be able to move the pit
your motor are not irreversible?
can you share some pics? :)
Postby seanbig » Sat 5. Jul 2014, 11:38
Hi Mat,
My motors are not irreversible, I use second hand motors. Is there problem with my motors? The brand new motor is all irreversible?
seanbig
Postby RacingMat » Sat 5. Jul 2014, 15:58
the smolka are irreversible: that's useful when you enter your simpit!
I would advice you to use a removable shim
or a kind of fork that lock your sim into horizontal position and the fork could be turned to free your sim
do you see what I mean?
because springs will only slow down all your dynamics and not maintain your pit...
yours
MAt
Postby seanbig » Mon 7. Jul 2014, 07:56
Hi Mat,
THanks for your advice, I might change brand new motors. Its much easier to me to do. Tanks again.
Sean
seanbig
Postby seanbig » Mon 7. Jul 2014, 07:58
By the way, if I change SCN5, can I use your code and present math to play or I need change both code and Xsim math to fit SCN5?
seanbig
Postby RacingMat » Mon 7. Jul 2014, 09:57
Hi!
It's not the same budget! 2 Smolka are 2x35€ + 16€ shipping.
Unfortunately the code won't work for scn5...
Postby hc26 » Thu 10. Jul 2014, 16:49
Hi all!
First of all, my compliments to RacingMat for this project, it's really awesome.
I've a question for you :D
Is your code compatible with the Arduino Duemilanove (2009) board?
Thanks in advance!
hc26
