2DOF rally motion seat
Re: 2DOF rally motion seat
Postby matsuda » Thu 11. Oct 2012, 09:52
Yeah, it would be great to see video of your rig in action
Can you also share your Math Setup for RBR with us?
BR, matsuda
matsuda
Postby spartan300 » Mon 12. Nov 2012, 10:25
hi all,
Finally i got the new motors (the same like those that Floriske has)
I was having problem with the old power supply(not many Amp).
I decide to make a new power supply.
Transformer 2X12Volt 2X45 Amp
2 bridge 45 Amp
2 capacitors 2,4 farad 24Volt
And all the system assemble.
Now i have the following problem. When i start the system and give power to the motors they make a rotation and they stop. :( :(
i dont know were the the problem is.
The transformer gives 2 different power supply's but in the controler the positive's are bridged.maybe they shouldnt be :!: :!:
Any suggestions.
Thank you
Loukas
spartan300
Images: 16
Postby sliversgyj » Thu 9. May 2013, 07:08
Hi,I want to know what's the function of those two 4f capacitors?
Thanks!
sliversgyj
Images: 34
Postby spartan300 » Wed 9. Oct 2013, 10:31
hi all,
After a period out, i am trying to finise my project.
i abounted Thanos Amc and bought an arduino R3 http://www.pololu.com/catalog/product/2191
http://imageshack.us/a/img841/8691/iqzv.jpg
i also bought Dual VNH2SP30 Motor Driver Carrier MD03A http://www.pololu.com/catalog/product/708
http://imageshack.us/a/img7/930/b3wh.jpg
and for pot those: SENSOR NON-CONTACT SINGLE TURN 6127V1A180L.5 http://www.digikey.com/product-search/e ... vendor=987
http://imageshack.us/a/img824/3699/a4i1.jpg
For programming the arduino i used this code:https://github.com/X-Sim/X-PID-Arduino-PID-motor-control/blob/master/XPID-Arduino-Firmware/XPID.ino
i have assambled all in the sim and will start testing it.
spartan300
Images: 16
Postby RacingMat » Wed 9. Oct 2013, 22:19
Good luck for your tests!
Be careful!
Thanks for sharing all this!
Mat
Postby spartan300 » Thu 10. Oct 2013, 10:06
Hi Mat,
Thank you.
I will visit France next week (Lyon) and i will go to europe's best simulation at i-WAY.
you know it?
Best regards
Loukas
spartan300
Images: 16
Postby RacingMat » Thu 10. Oct 2013, 10:56
you're lucky: :P
friends of mine went at iWay and have been blasted!!!
Postby spartan300 » Tue 29. Oct 2013, 21:45
UPDATE 25/10/2013
2263226122622272227122702268225922582260
spartan300
Images: 16
Postby prodigy » Tue 29. Oct 2013, 22:31
Can this Pololu driver handle those big motors?
I had big troubles with same motors ZYT90 and Pololu JRK's, I also did the similar rear mount like you and I couldn't get it to work, JRK's couldn't handle that load and they were "choking". I had to resemble everything and do the shoulder mount to make it work.
I'm curious to see how this is going to work, have you already tried it?
Postby spartan300 » Tue 29. Oct 2013, 23:37
prodigy wrote:Can this Pololu driver handle those big motors?
i made i few tests, they move it but sometimes they act like they are "loosing" there position and move free.
I will try to make a video with the setting and the problems that happens.
spartan300
Images: 16
Users browsing this forum: No registered users and 60 guests
