3DOF power simulator
Re: 3DOF power simulator
Postby tronicgr » Tue 21. Aug 2012, 21:01
Hi thecure,
You mean like this one? http://www.ebay.com/itm/1-pcs-ATMEL-ATM ... 910wt_1267
Yes, that is one way to get Atmega644. But maybe you can try using Farnell as they have other parts that you can order along.
The "FTDI - UM232R - EVALUATION KIT, USB-UART, TTL, FT232RL" in the link you gave above, is not directly compatible with AMC1.6. You will have to rewire it to use it as it has different pin number assignments.
Thanos.
Postby thecure » Tue 21. Aug 2012, 23:00
ok...tks I found everything on ebay ... diplay and chips. The board FT232RL USB to Serial Module USB from america (---the time is sooooo long:D )
thecure
Been thanked: 5 times
Postby motiondave » Wed 22. Aug 2012, 01:56
thecure wrote:ok...tks I found everything on ebay ... diplay and chips. The board FT232RL USB to Serial Module USB from america (---the time is sooooo long:D )
then perhaps buy jrks and have them on your doorstep in 3 days.......
Really, give the suppliers a chance...the tronic is a good board , even if some parts take time to get there....
Postby thecure » Wed 22. Aug 2012, 18:14
the crystal 22.1184 mhz, it' 16 pf not 18pf.....can fit ;)
thecure
Postby tronicgr » Wed 22. Aug 2012, 18:48
16pf crystals are usually SMD package (really tiny surface parts).
You need to make sure its a through hole part:
http://www.newark.com/citizen-america/hc49us22-1184mabj-ub/crystal-22-1184mhz-18pf-thru-hole/dp/59K8188
Postby thecure » Tue 28. Aug 2012, 16:57
and I got the chip, but I know that is not the right one
and ATMEGA644-20PU-16 MHz 8-bit 64K-FL-2K RAM-EE 2.7 to 5.5 V 40 DIP
if its not right .. this?
http://www.ebay.it/itm/ATmega644P-20PU- ... 4603d007e1
thecure
Postby tronicgr » Tue 28. Aug 2012, 18:08
thecure wrote:and I got the chip, but I know that is not the right one
Hi Thecure,
The "ATMEGA644-20PU-16 MHz 8-bit 64K-FL-2K RAM-EE 2.7 to 5.5 V 40 DIP" is correct chip.
I don't know why they marked it "16Mhz" since they already put the correct speed right before that: "20PU"
Best Regards,
Postby thecure » Tue 28. Aug 2012, 19:01
ok...tks ;)
thecure
Postby thecure » Mon 3. Sep 2012, 19:06
:D I mounted the PCB and everything works :D Does the circuit works with version 2.0 of the x-sim ? ...tks
thecure
Postby basthard » Tue 4. Sep 2012, 11:59
thecure wrote::D I mounted the PCB and everything works :D Does the circuit works with version 2.0 of the x-sim ? ...tks
I tronicgr
a little ignorant question:
believe that the motor for the rotation of the base we can omit the reference potentiometer or encoder? :roll: :roll:
doubt it is because the rotation is free ...
without reference only the data of X-SIM :( :(
always sorry for my "perfect" English :lol: :lol:
Basthard
basthard
Users browsing this forum: No registered users and 27 guests
