3DOF power simulator
Re: 3DOF power simulator
Postby thecure » Fri 29. Aug 2014, 21:09
antother question on figure 4.2 the 5v go to directly in your board ? tks
thecure
Been thanked: 5 times
Postby tronicgr » Fri 29. Aug 2014, 21:18
Yes, you can use the 5v from the controller
Postby thecure » Fri 29. Aug 2014, 21:38
how to use it.?...it is essential to run the motors ? tks again
thecure
Postby tronicgr » Fri 29. Aug 2014, 22:07
You will have to build the RC filter on the figure 4.2. What is does is to convert the PWM pulses to analog voltage. Its best to check the output signal with oscilloscope to verify that the RC filter is efficient and does not create ripples.
Postby thecure » Sun 31. Aug 2014, 16:59
can you help me !!!! could you please help me with electrical connection,you can look the picture below...tks
thecure
Postby thecure » Sun 7. Sep 2014, 12:07
:roll: :cry:
thecure
Postby thecure » Mon 29. Sep 2014, 18:29
in this picture there is a capacitor whit value 47uf ....i have two option .One is this http://www.tme.eu/it/details/mks4-47u_6 ... 6g00kssd/#
the other is this http://www.tme.eu/it/details/tap476k035 ... -tht/avx/#
there is no difference ?
thecure
Postby tronicgr » Mon 29. Sep 2014, 19:03
This one is better: http://www.tme.eu/it/details/mks4-47u_63/condensatori-al-poliestere-tht/wima/mks4c054706g00kssd/#
The other is Tandalum type and is not good for this purpose.
Why not use an electrolytic one?
Like this one: http://www.tme.eu/it/details/uvr1e470mdd/condensatori-elettrolitici-tht-85c/nichicon/# 8-)
Postby thecure » Mon 29. Sep 2014, 22:30
because in the scheme it is not specified....so i can use also an electrolitic
thecure
