Postby RacingMat » Sat 1. Feb 2014, 21:21
Hi!
My simulator is on sale now as I have more room for bigger projects!
It is ready to use and complete (PSU, motors, cards, MOMO logitech wheel) you just have to plug USB cable on your Gamer PC!
The price is 600€ and it has to be picked up in South of France - Marseille ;-)
yours
Mat
_____________________
Bonjour à tous !
J'ai un nouveau projet de simu ... et donc je vous propose d'acheter mon simulateur 2DOF pour 600€
si le Père Noël ne vous en a pas laissé un sous le sapin, c'est le moment !!
Il est à venir chercher près de Marseille.
Il est entièrement complet (alim, baquet, volant MOMO, moteurs, électronique...) !
Il n'y a qu'à brancher le simulateur sur votre PC de jeux (une prise USB) après avoir installé Xsim : et roulez jeunesse !
Il fonctionne vraiment super bien ! Tous ceux qui l'ont testé ont été emballés...
Mat
Postby chanzu » Sun 23. Feb 2014, 05:21
hi racingmat,
how come you can drive 24v motor with 12v power supply? and how much the ampere will be used on motor?
because the motomonster maximum ampere only 30a right?
chanzu
Postby RacingMat » Sun 23. Feb 2014, 13:34
hello Chanzu!
driving 24V motor with 12V supply makes only them turning half max speed: in my case, it is enough.
I've written the currentconsumption in first post: 90W per motor -> 7,5 A in 12V DC
Mat
Postby vell001 » Sun 9. Mar 2014, 17:48
I have started my own project(http://vblog.vell001.ml/2014/03/09/vsim.html), thanks for your post very much
vell001
Postby Monaco85 » Wed 12. Mar 2014, 23:44
Hey mat
I use your arduino software today for first test with serial monitor.
I have a question. Is it normal. One of my motors work faster tha the other.
And sometimes one motor doesnt react at all. The i have to change the position.
Monaco85
Postby RacingMat » Wed 12. Mar 2014, 23:53
Hi !
@ vell001! Congratulations!
@ monaco85: please give more details about your motors.
Did you try to permute them (left to right and right to left)?
Did you purchase cermet pot?
Yours
Postby Monaco85 » Thu 13. Mar 2014, 08:12
I have the same motors than u have and cermet pot.
I have a crank of 10 cm and you wrote someting about 6cm . Is this maybe to much for the wipers?
Monaco85
Postby RacingMat » Thu 13. Mar 2014, 08:30
Yes, 10cm is un necessary and too much!
What is the weight of you + platform?
What code are you using? What is the value of Tol in the code? Did you change it?
Postby Monaco85 » Thu 13. Mar 2014, 08:44
Okay.
I played with the tol. From 10 up to 50. But the std 20 is the best.
I will change my crank these days.
I whink my moving platform is with wheel about 30 kg.
Monaco85
Postby RacingMat » Thu 13. Mar 2014, 15:18
Ok!
About your slow motor:
- Did you try to swap the motors? Does the same motor stay slow? or not?
- Or did you try do power them directly?
Users browsing this forum: No registered users and 57 guests
