Postby RiftFlyer » Mon 16. Feb 2015, 20:05
homemonster wrote:why y dont use oculus dk2 or vr gear(samsung)?
The Rift won't work with a high angle motion platform. The base movement will be mistaken by the rift IMU as head movement. The IR camera does not have a high enough refresh rate to correct this and actually adds to the problem creating more judder and unwanted view movement.
The GearVR from Samsung can only play games designed for its Galaxy note platform and is unlikely to be able to output g forces for a sim.
RiftFlyer
Images: 22
Postby vicpopo » Tue 17. Feb 2015, 19:06
The solution is here http://www.vectionvr.com developed by a guy !
The only main problem is that the developer needs to put into the game his library and until niw only 2 games are supported LFS and one more Prepa3D which is on test.
Postby DustinGadal » Sun 8. Mar 2015, 00:28
It looks like Valve's Lighthouse is going to be the solution you want:
http://www.vg247.com/2015/03/05/valves- ... explained/
DustinGadal
Postby Riton » Fri 28. Aug 2015, 00:28
Hi , news ?
i hope you have no problems...
no news, no video ....
Riton
Images: 70
Been thanked: 16 times
Postby asticher » Wed 2. Sep 2015, 21:50
This projekt is insane! Hope to here more soon. Also thx for this hint:
I never thougt about this problem!
"No Brain, No Pain"
asticher
Images: 20
Postby Xmotion » Sun 13. Sep 2015, 18:35
WOW
excellent work!!
Xmotion
Postby tronicgr » Mon 14. Sep 2015, 01:00
I hope Damien is ok, his email was hacked I assume as I received a phishing email from his account that had CC all many of his friends... :|
Perhaps he is too busy lately to present any of his progress.
Postby homemonster » Fri 9. Oct 2015, 20:47
Hi. I have vr helmet with 2048×1536 and tracker for motion platform. Price 1200 euro.
The special sensor head rotation - tracker consisting of gyroscope, accelerometer, magnetometer, temperature sensor, a processor with a unique firmware to solve problems with drifting.
• The lens made of optical glass providing mechanical strength and is several times less distortion.
• Special inner part, consisting of foam and eco silicone provides the user with greater hygiene and comfort.
• The design of the helmet shell, you can use it outdoors, as well as with glasses.
• A special fastening system to help you easily and securely fix the helmet on the user's head.
homemonster
Postby ibrahimozcan » Fri 27. Nov 2015, 16:10
your simulator is very nice ;)
ibrahimozcan
Postby tronicgr » Fri 27. Nov 2015, 16:48
He is back to work on this project!!!
New video:
https://www.youtube.com/watch?v=3sRkjjpczao
