My 2DOF simulator with sew eurodrive geared motors
Re: My 2DOF simulator with sew eurodrive geared motors
Postby tronicgr » Sat 8. Sep 2012, 21:45
This looks great!!! I would like to see a video with it in motion...!! Nice Job!
And yes.. Lucky guy... I wish I had such equipment just given to me like that! :lol:
Postby vicpopo » Sun 9. Sep 2012, 10:29
tronicgr wrote:Hi,
If you would decide to live in France near Strasbourg you will be a lucky guy too . :lol:
Believe me my friend !!! :D
Postby floriske » Sun 9. Sep 2012, 12:53
A.C. motors ftw! ;)
Can't wait to see this one up and running!
floriske
Images: 96
Postby vicpopo » Sat 15. Sep 2012, 18:27
Hi everybody,
I updated the topic http://www.x-sim.de/forum/viewtopic.php?f=37&t=293#p2058 with pictures and ideas for ''how I mount the magnets '' for using a hall sensor as potentiometer.
Regards
Postby Turn » Wed 24. Oct 2012, 12:29
Hey - just wondering if anybody's noticed any AC motor heating problems when running them with VFD inverter drives? The reason I ask is because most AC induction motors are *not* designed to run the low/zero speeds used in motion simulators because their integrated fans don't work well there. Anybody noticed any problems so far?
Turn
Postby Roadster2 » Wed 24. Oct 2012, 12:36
Hopefully you'll get a response or two from members that are actually running AC motors but just in case - I have previously seen a posting (can't remember which web forum) which had photo's of the AC motors. On each motor the plate over the connection box had been removed and a 12V DC fan fitted, to provide cooling directly into the motor.
Roadster2
Postby vicpopo » Wed 24. Oct 2012, 17:02
I will check this point whis this simulator .I don't have termal driving in these motors , if the temperature will go up 70 °C I will put fans on the motors .It's also dangerous if someone touch them.
When I look at ckas configurations , the old one have fans fitted on the motors and the new one any .For the old one if you look at these fans there are not big in comparaison of the motor power .
The ckas first price 2dof Thruxim (motor 0,12 kW) has no fan fitted.
With an inverter configured in Vector Flow control the Ac motors will be drive in all parameters we need for motion.
I tested the output shaft torque is uncredible!!With very low rpm (low frequence) you can't move anything.
Best Regards
Postby Riton » Wed 24. Oct 2012, 18:59
in the industry, these engines are also used in similar conditions.
There are forced ventilation unit to cool the engine.
I have one on my engines forced continuous ventilation to avoid heating of the motor.
Riton
Images: 70
Been thanked: 16 times
Postby vicpopo » Fri 2. Nov 2012, 20:18
Hi everybody ,
I updated the topic with the first tests.
Enjoy
Link:http://www.x-sim.de/forum/viewtopic.php?f=37&t=293#p2058
Best Regards
Postby yokoyoko » Fri 2. Nov 2012, 20:23
This setup is so sick. Please try not to kill yourself :D your motors would be strong enough!
With a fitting math-setup this has to be awesome.
