Sim Project - 2DOF K8055+Sabertooth 2x12 -(SOLD)
Re: Sim Project - 2DOF K8055+Sabertooth 2x12 -Stage 2
Postby kevin123 » Mon 16. Sep 2013, 19:44
menix wrote:Hi
So far i use the settings in this topic.
But my motor turns immidiately after i start xsim .
how can i solve the problem?
thx
menix
Hello Menix
Can you explain what the problem is because I did not understand
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby menix » Mon 16. Sep 2013, 20:35
hi
for the moment i use vellemann K8055 and Sabertooth.
When i start Xsim i have always to go interface settings and set the output controll at 50%.
Because Sabertooth gives 0 backward 2,5V Stop and 5V Forward.
So when i start Xsim and power the Motors they always goes to Limit.
I wanna that the Power is set to 2,5 V when i start Xsim. But i dont know how to do this.
I hope you understand
menix
menix
Postby prodigy » Tue 17. Sep 2013, 10:20
I think all of us who used K8055 had same problem, this was my procedure:
- I plug-in K8055 USB, open X-Sim Converter, go to "Interface" tab and set output to 50%, turn on motors (release emergency button) and they stay in position.
Some of people here made a workaround with car relay - take a look at Vicpopo's solution
http://www.x-sim.de/forum/viewtopic.php ... =254#p1415
Postby kevin123 » Tue 17. Sep 2013, 20:57
menix wrote:hi
menix
Hello
If you follow these settings you should have no problems and do not have to put interface settings and set the output controll at 50%
114211411140 ;)
kevin123
Images: 132
Postby menix » Wed 18. Sep 2013, 17:07
And how do you start the simulator?
First X-Sim
then Play game
then start the motors
or how?
mennix
menix
Postby sirnoname » Wed 18. Sep 2013, 21:42
No problem to insert a setup dialog, but I do not understand your setup!
If the velleman is conected it will always be in a unknown state. What happens if the software starts compared to velleman without software?
Someone can offer a wiring diagram here?
Postby kevin123 » Thu 19. Sep 2013, 21:24
sirnoname wrote:No problem to insert a setup dialog, but I do not understand your setup!
I did not understand your speech in that sense velleman would be in unknown state? Yet with these settings work perfectly.
This is my wiring diagram
1990
EDIT: Sorry Sirnoname the question was directed to me or Menix?
kevin123
Images: 132
Postby gigifux » Tue 19. Nov 2013, 10:45
Ciao kevin!
Credo che oramai i complimenti si sprechino per il tuo progetto davvero ben realizzato!
Sono in procinto di realizzare un simulatore dinamico 2dof. Premetto che ho una discreta
manualità meccanica ma ahimè non ho conoscenze di elettronica. Vedo pero' che in questo forum
ci sono moltissime informazioni ed utenti disposti a condividere le loro conoscenze ed esperienze.
Comunqu per il momento mi voglio concentrare sull'aspetto meccanico. Affrontero' in seguito
le problematiche elettroniche.
Riguardo al tuo progetto Vorrei chiederti alcune cose:
1) Come mai hai scelto di dare trasmettere il movimento generato dai motori attraverso delle lunghe
sbarre dotate di snodi e fissate nella parte alta dietro al sedile, soluzione peraltro adottata da molti...ma non da tutti. Ritieni che questa soluzione presenti dei vantaggi rispetto alla soluzione usata ad esempio da stephaned61 http://vos-playseat-stephaned61.xooit.f ... -glace.htm .
2) Ho visto che hai installato ai lati due meccanismi chiudiporta. Che funzione hanno?
3) Vedo anche che hai installato due braccetti snodabili fissati vicino alla pedaliera. che funzione hanno?
4) Che dimensioni ha il tubolare di ferro che hai usato?
Ti ringrazio per la disponibilità
gigi
Hello kevin !
I believe that by now you are wasting the compliments for your project really well done !
They are going to realize a dynamic simulator 2dof . I state that I have a fair
manual mechanics, but I do not have knowledge of electronics. I see , however, ' that in this forum
There is lots and users willing to share their knowledge and experiences.
Comunqu for the moment I want to concentrate mechanical appearance . Shall approach ' later
electronic issues .
I would like to ask you about your project a few things :
1 ) Why have you chosen to convey the movement generated by the engines through lengthy
bars with joints and attached at the top behind the seat , a solution also adopted by many ... but not all . Think that this solution has its advantages compared to the solution used for example by stephaned61 .
2 ) I saw that you installed on the sides two mechanisms closers . What function do they have?
3 ) I also see that you have installed two adjustable arms set close to the pedals. what function do they have?
4 ) What are the dimensions of the tubular iron that you used ?
Thank you for availability
gigi
gigifux
Postby Erius81 » Sun 24. Nov 2013, 18:47
Ciao Kevin,
Sono appena entrato a far parte di questo mondo ma purtroppo non capisco tanto bene l'inglese.
Innanzi tuttu Complimenti per il tuo Playseat!
Avrei un problema: Con x-sim, non rieco ad avviare i giochi che ho su steam. Cliccando sulla scritta "Play game" mi appare un finestra con scritto "steam cannot be initialized. Closing".
Premetto che con i giochi "non steam" non ho nessun problema.
Tu mi puoi aiutare?
Erius81
Postby billo2404 » Wed 27. Nov 2013, 18:05
Ciao kevin, visto che di complimenti ne avrai ricevuti una marea non ti darnno fastidio i miei :P
scherzi a parte non vorrei disturbarti in privato quindi stavo cercando la tua guida sulla configurazione di x-sim che avevo visto tempo fa.
Non riesco più a trovarla, percaso è stata cancellata?
E' possibile recuperarla da qualche parte, grazie
billo2404
Images: 72
Has thanked: 7 times
