Postby RacingMat » Tue 21. Jun 2016, 21:53
At which step of the tutorial are you stuck?
Postby TomKlash » Thu 30. Jun 2016, 07:37
I have a question about the electrical connection between ARDUINO UNO and MOTO MONSTER. If i choice to mont MOTO MONSTER on ARDUINO CARD can i plug all pins or just this ? Cause It's more simple to connect all pins and have all acces on the top of MOTO MONSTER to connect potentiometer for exemple...
Arduino .../...Motomonster
......GND <-> GND pin
........5V <-> 5V
.....pin 4 <-> pin 4
.....pin 5 <-> pin 5
.....pin 6 <-> pin 6
.....pin 7 <-> pin 7
.....pin 8 <-> pin 8
.....pin 9 <-> pin 9
pin 13 is not needed
on the pictures, I've soldered more wires (but they are unused wire...).
Arduino and Motomonster stacked %285%29.JPG (12.7 KiB) Viewed 16340 times
TomKlash
Images: 40
Postby RacingMat » Thu 30. Jun 2016, 07:52
Stacking the 2 boards is fine! :-)
Postby TomKlash » Thu 30. Jun 2016, 08:40
Connecting all pins ?
TomKlash
Images: 40
Postby Leme » Tue 12. Jul 2016, 15:15
I like your project, but I have a question. The two 24V motors are conect in 12V output Monster Moto Shield?
thanks.
Leme
Postby cpnemo » Wed 21. Sep 2016, 11:42
Hi everyone and RacingMat
I have problem about my project such as......
1. I'm not sure the converter and extractor work to correct ?
2. My DC Motor respond especially Right side but Left side don't work because ? (Arduino+Monster motor shield)
p.s. I will follow you step to step.
Thank you for reply.
cpnemo
Postby Bora » Thu 2. Mar 2017, 02:23
Firstly thanks for your topic it's very useful,
I have a problem and a question also, I built a prototype and I'm testing position and movement from Arduino Serial Port, when I testing it, the motors are too fast. I use 12 V DC 55 rpm Wiper Motors.
What should I do?
How can I reduce the speed of motors?
If I drop the speed in arduino program, will the speed decrease while playing with xsim?
I thank you for your response...
Bora
Images: 12
Postby RacingMat » Thu 2. Mar 2017, 09:41
Thanks Bora!
Your motors specifications look good and not too fast. :!: personnaly, I would advice 70rpm
You could reduce the speed in the code but, in fact, under load, the speed will significantly decrease. Don't bother about this :D
Postby Vinicius » Mon 6. Mar 2017, 22:09
I'm from Brazil and I'm writing to thank you for your post. With them and other articles here of the forum, I was also able to mount a simulator 2 dof. Follow test video.
Https://www.youtube.com/watch?v=2NykL-YF6Nc
Tks
Vinicius
Vinicius
Postby RacingMat » Tue 7. Mar 2017, 11:19
congratulations! you achieved your goal 8-)
seeing your video, you will be able to add more details to your movement by spending some time for tuning the profiles
your sim could be more lively
