Postby RacingMat » Fri 12. Jun 2015, 11:15
hello,
What was wrong with standard potentiometer? Maybe you should explain us this, it could be useful even for your multi-turn pots
About multi-turn pots, if you want to keep precision, you have to use gears.
what is the gear ratio you intend to have?
Mat
Postby jolebaleze » Sun 1. Nov 2015, 15:46
Great job racingMat!
I was inspired enough by your work to start a playseat project.
My page is here:
viewtopic.php?t=2194
I wrote an Arduino code compatible with your 'RxxLxx' protocol but based on PID.
You can find it in my thread.
Thanks again for your work and feel free to comment mine.
jolebaleze
Postby willwf » Thu 5. Nov 2015, 06:30
:D :D :D
willwf
Postby Poulps » Sun 15. Nov 2015, 15:50
Your project is really the most inspiring!!!!
I have assembled it and worked fine at first try !
I´m having some troubles with Project Cars and XSIM setup, but I´m searching about it.
Thank you very much for share your knowledge with us !
Kind Regards !!!
Paulo - Brazil
Poulps
Postby RacingMat » Sun 15. Nov 2015, 19:54
Thanks very much Paulo for your feedback :)
I'm really glad to know that my tutorial helped you as far as Brazil!! I whish I could come and see your simulator!
PS: I'm not using PCars so I can't help you further
Postby FranciscoJr » Thu 26. Nov 2015, 18:18
Congratulations for your work. He was inspired to make my own.
However I am having trouble with one of the engines.
I'm testing it with the rfactor.
To leave the game the engine is back to work, causing the potentiometer do not get to zero and thereby takes off immediately and manually the simulator.
At first I thought it was problem in potentiometer, changed him and continued the same way, but now I do not know what it is.
If you can help me I will be very grateful.
FranciscoJr
Postby RacingMat » Thu 26. Nov 2015, 21:00
Hi!
Glad you found inspiration!
Can you share screenshots of your setup ans pictures of your wiring?
Mat
Postby FranciscoJr » Mon 30. Nov 2015, 13:03
RacingMat wrote:Hi!
Mat
I managed to solve the problem.
It was the screw was loose. :D
FranciscoJr
Postby RacingMat » Tue 8. Dec 2015, 11:43
well done! good news
little things can be really bothering... :x
Postby promy » Sat 9. Jan 2016, 00:26
Your build was extremely usefull and very nicely done!!!
I used it as a guideline to build mine over the past weeks. I am using the whiper motors mounted in front of the seat between 2 wooden boards (like the logo of x-sim)
When manually giving orders to the arduino everything goes ok (sometimes a bit of jitter) , however when using it when running gtr2 i sometimes get very unrealistic movements: eg: it starts hanging a bit to the front left, or all of the sudden it thinks its braking when just driving...
Any idea's how to solve these problems?
promy
