Sim Project - 2DOF K8055+Sabertooth 2x12 -(SOLD)
Re: Sim Project - 2DOF K8055+Sabertooth 2x12 -Stage 2
Postby kevin123 » Wed 3. Jul 2013, 19:30
GearedGeek wrote:@kevin123,
How is 2DOF connected to your computer and do you have two computers running? I seen from one build where they use two computers to run it. Also what type of wiper motors did you use? Does it matter what brand of ATX 200watt power supply you use? In your current build what are the arms in the front by the seat and by the pedals?
Hi GearedGeek
1) I just preferred to use a computer because it is powerful enough to use x-sim games and at the same time
2) I used engine wipers of a fiat panda see that we wrote in my post;)
3) I used a standard ATX ATX PC 200 W to feed the potentiometers and the cooling fans
4) The arms are limiters of horizontal oscillation because the sim has an articulation of a ratchet and serve to limit the game to the right and left.
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby kevin123 » Sun 21. Jul 2013, 19:02
Added dashboard with galaxy s4 thanks to the new function of x-sim 3 ;)
kevin123
Images: 132
Postby vicpopo » Sun 21. Jul 2013, 20:24
Hi ,
Nice job with your galaxy dashboard !! ;)
Postby kevin123 » Thu 25. Jul 2013, 20:25
Hi
thanks vicpopo
It also seemed the most economical solution since the galaxy I already had bought only torque pro € 2.55 and € 2.89 meter racing ;)
kevin123
Images: 132
Postby gaevulk » Sun 15. Sep 2013, 16:45
ciao kevin,ho un problema e volevo chiederti una mano
ho questi setting nello speed value, nello screen lo spped sta' all'85% ma di solito lo tengo al 90%,ora pero' con questo setting i motori emettono delle vibrazioni anche quando sono fermi,senza avviare alcun gioco ma semplicemente avviando x-sim
non riesco a capire se la cosa dipenda dalla saber/k8055 oppure sono i motori ormai usurati,non so,dici che potrei ovviare con qualche accorgimento nelle impostazioni?
purtroppo queste vibrazioni sono belle fastidiose
2091
hello kevin, I have a problem and I wanted to ask you a hand
I have these settings in the speed value, the screen is the spped '85% but I usually keep it at 90%, but now' with this setting engines emit vibrations even when stationary, without opening any game just start x sim-
I can not understand if it depends on the saber/k8055 or engines are now worn out, I do not know, you say that I could overcome with some changes in the settings?
Unfortunately, these vibrations are beautiful annoying
gaevulk
Images: 9
Postby prodigy » Sun 15. Sep 2013, 17:41
I had the same small vibrations while standing still. I think it's related to potentiometers and K8055, not with the motors itself. It's like the board is too sensitive with potentiometers, the numbers are constantly moving up and down and so are the motors.
But eventually I got used to it because once you are in the game, you don't notice it that much..
Postby soraz » Sun 15. Sep 2013, 19:14
where recoveries the gears for motor-pots ?
thanks
soraz
Images: 67
Been thanked: 7 times
Postby menix » Sun 15. Sep 2013, 20:06
Hi
So far i use the settings in this topic.
But my motor turns immidiately after i start xsim .
how can i solve the problem?
thx
menix
menix
Postby kevin123 » Mon 16. Sep 2013, 19:32
gaevulk wrote:ciao kevin,ho un problema e volevo chiederti una mano
2091
Ciao gaevulk
Queste vibrazioni ai motori le senti anche con altri profili?
Io lo speed dinamic lo uso al 100% e non fà alcun tipo di vibrazione solo quando parte il gioco vibrano però quello e normale simula che l'auto e in moto. Può essere che dipenda dai potenziometri io ho messo quelli di precisione... quelli che avevo prima mi davano problemi erano troppo sensibili.
Prova ad abbassare anche Pid control e parti da 1 a salire e vedi che reazione hanno i motori non sò a che serve (non ho mai letto il manuale di x-sim :oops: ) sò che se aumento i motori hanno reazioni più violente
Hello gaevulk
These vibrations to the engine feel even more profiles?
I use it dinamic speed to 100% and does not make any kind of vibration only when part of the game, however, that vibrate and normal simulates the car and motorbike. Maybe that is I put those potentiometers, precision ... the ones I had before gave me problems were too sensitive.
Try lowering Pid control and also parts 1 to go up and see what reaction they have the engines do not know what good (I never read the manual of X-SIM :oops:) I know that if I increase the engines have most violent reactions
kevin123
Images: 132
Postby kevin123 » Mon 16. Sep 2013, 19:42
soraz wrote:where recoveries the gears for motor-pots ?
thanks
The gears will find them in stores carrying pulleys or servo motors steel ones mine are plastic and I have just recovered from a servo control of a 3-way valve for heating
Or search google there are sites that sell them all kinds like this http://www.specialingranaggi.com/it/index.html
kevin123
Images: 132
