Postby moj9999 » Mon 22. Dec 2014, 22:16
hi
did you know what is the setting in x-Sim , every time i try it didn't response!
can you help me.
if your x-Sim work properly can you take picture and send to me !
thank you
moj9999
Postby Mornica » Sun 28. Dec 2014, 07:56
I am fundas samsung galaxy alpha just starting a 2 dof sim following your guide here. Thanks for all the detail fundas galaxy note 4.
Mornica
Postby RacingMat » Sun 28. Dec 2014, 23:32
@moj9999 : sorry, since I have sold my 2DOF, I haven't a working computer with Xsim to make some screenshots
@mornica : welcome here! have fun!
I would advice you to stick to the list: it'd be easier to help you ;)
Postby impalone » Thu 8. Jan 2015, 13:46
Hello guys, it's me again. I have a doubt. The size of the electric cables? Has anyone had problems with cables from 2.5mm? greetings
impalone
Postby RacingMat » Thu 8. Jan 2015, 14:13
What is the wattage of your motor? And voltage?
With this information, we could help you to calculate the section (in mm2)
Postby impalone » Sun 11. Jan 2015, 12:53
Hello Guys, I'm using the same type of engines in the post of which we speak, another question, the motors must turn to the inverse of the pot or when the pot has to turn around in the same direction?
impalone
Postby RacingMat » Tue 13. Jan 2015, 10:05
@impalone :
yes, you can use 2.5mm² wires
@ 20A continuous
and 30 cm length between driver and motor
-> the wire will heat 37°, which is below the 60° max heat.
http://www.plaisance-pratique.com/spip. ... article=88
Have shortest possible wires between driver and motors!
how the pot are mounted? can you draw a sketch? or share a picture?
follow the step by step instruction:
- if your pot is fully turned to max, as Arduino "reads" potentiometer value as motor position, Arduino believes that motor is in max position.
- but the order is to be in middle position
- so the Arduino will ask the motor to go reverse in order to go to middle position
- your motor is turning
- but while your pot keeps still, the motor will turn non stop !
- when you manually turn the pot backward to min, Arduino reads that motor is in min position
- but the order is still middle position, so Arduino will tell the motor to go forward
- motor runs non stop until the pot is in middle position
In the code, you have a "tolerance" parameter : when the pot is around middle position (<middle+tolerance and >middle-tolerance), the motor stops.
You can broader Tolerance value to stop your motor more easily manually.
Postby moj9999 » Sat 21. Feb 2015, 23:43
RacingMat where are you!
did you receive my message!
moj9999
Postby moj9999 » Tue 24. Feb 2015, 19:31
hi
i had problem with x-Sim software then i wrote my program in c# that get data from fsuipc and send it to arduino ,my problem is ,what is data shape and type that you arduino program recognize !
it's difficult for me to write program for arduino !!
please help me
thank you.
moj9999
Postby RacingMat » Tue 24. Feb 2015, 22:58
If you dont share the code you wrote, how could we help?
I bet it would be easier for you to succeed with an authentificated solution rather than writing new code
