baileysw wrote:Guys,
Sorry to resurrect an old thread but I am still confused about the height of the seat, universal joint etc.
In reply to a question, Floriske said an an older thread -
Whats the height between the base and the bottom point of the pivot?
I have done a lot of frames, from 140mm to 400mm high in frame height.
The chairs base, the moving base or the compete sim's base?
The first is approx. 30cm, the second approx 7,5cm and the latter approx 25cm.
Sorry to be so thick, but could you clarify the above measurements? I am assuming the bottom point of the pivot is the lower universal joint. If I understand it right, the height between this joint and the chairs base is 30cm and the height between this joint and the complete sim's base is 25cm, giving around 55cm from the sim base to the chair base in total. This is quite a bit higher than 40cm. I am not sure what the moving base is. Is this the base on which the seat slides?
Users browsing this forum: No registered users and 23 guests
