Postby RacingMat » Mon 19. May 2014, 17:01
Hi Sean!
It's probably a good start :-)
It's rather sensitivity of the profile rather than the code.
Did you try first without game but only power On and manually turning the pots?
Mat
Postby seanbig » Mon 19. May 2014, 17:07
Hi Mat,
Thanks for your rapid reply, I guess my MATH is not setting well. Now I am checking {Professional profile making by yokoyoko} file, please give me some time to figure out the MATH setting, and I will come back to you soon. Thanks.
BR,
Sean
seanbig
Postby RacingMat » Mon 19. May 2014, 17:41
You're welcome :-)
and tell us more soon! You'll enjoy your sim shortly hopefully
Postby seanbig » Tue 27. May 2014, 10:57
Hi Mat,
Have you try buttkicker mini in your sim. I can only buy mini version here, is that feel good also?
BR,
Sean
seanbig
Postby RacingMat » Tue 27. May 2014, 12:06
No, I've tried DIY buttkickers, bass shakers and Throne Thumper.
Bass shaker are good for 2x 12€ and Throne is excellent! :D
Did you solve your problem?
Postby seanbig » Tue 27. May 2014, 12:36
Hi Mat,
My math setting is okay, and looking good. Thanks. Now I am welding the frame and final testing. I hope I can done my prototype soon.
Can you share me some buttkicker DIY information?
PS. You are so amazing like MacGyver, I am so impressed.
BR,
Sean
seanbig
Postby RacingMat » Tue 27. May 2014, 13:49
;) thanks!
Here is a tutorial I wrote about DIY buttkicker
Postby seanbig » Wed 28. May 2014, 02:05
Thanks Mat
seanbig
Postby Pavlado » Fri 30. May 2014, 09:28
Hi, I have a problem with the USO settings. I have set the following values​​:
Datapacket: R7FL7F
data's format: R ~ ~ L ~ a1 a2 ~
send packet on simstop: R7FL7F
But when I click the Start pop up window like this:
Where cen be a problem?
Pavlado
Postby RacingMat » Fri 30. May 2014, 11:53
Hi Pavlado!
Probably you have check too many interfaces in Xsim.
It tries to open different serial communication on same ComPort.
You only need USO interface: uncheck other plugins in the different tabs ;)
(Can you send the screen shot of your interface setup ?)
yours
Mat
