Postby seanbig » Tue 29. Apr 2014, 14:23
Hi Mat,
Can I use servo motors on your system and your code? Here is the website and photo I want to buy, but not sure it works on it. Please give me some comments. website: http://item.taobao.com/item.htm?spm=a23 ... 8f48hs7125
Thanks.
Sean
seanbig
Postby RacingMat » Tue 29. Apr 2014, 17:26
Hi!
Servo motors are not the best choice for simulator: their torque decrease quickly with speed
and you need high number of poles and quick electronic for smooth movment
hence you need costly drive
... as far as I have understood on french forum
Postby seanbig » Wed 30. Apr 2014, 03:24
Hi Mat,
Thanks for your reply, I spent lots time to search wiper motor and now I found one use in the truck(disel 2000.cc). Could you comment me if 12V 50W (low speed 40/min. high speed 60/min.)wiper motor is enough or not. Thanks.
BR,
Sean
seanbig
Postby RacingMat » Tue 6. May 2014, 18:04
Hi Sean!
Their specs look standard and if it comes from a truck, it's a good point imo!
Do you have some news? :)
Mat
Postby Dovale » Mon 12. May 2014, 13:23
Great job
I built a similar system but with a Link2FS software.
Without FSX motors react according to pot change.
However wjen connected to FSX motors work contiinuesly.
I suspect that there is a difference in the definitions between the spftwares.
Are you familiar with Link2FS? I use only pitch and roll expressed as Q and are.
Dovale
Dovale
Postby RacingMat » Mon 12. May 2014, 15:49
Great job
Thanks Dovale! 8-)
I don't know "Link2FS software": do you have some links to share?
I'm sure we all would appreciate if you share some pictures... ;)
Mat
Postby Dovale » Mon 12. May 2014, 16:35
Thanks for immediate response.
http://www.mycockpit.org/forums/arduino ... ds-link2fs
http://www.jimspage.co.nz/multi_starter_pack.htm
The developer is Jim from NZ
From his page you will have all updates etc'
Thanks again
Dovale
Dovale
Postby RacingMat » Mon 12. May 2014, 16:48
You're welcome!
I have found the post where you describe your pb: http://www.mycockpit.org/forums/showthread.php?t=27887
I can tell you what Motomonster expects but you have to tell me what Link2FS is sending: there are too many many pages for me to dig through...
Can you find exactly what is the data format of Link2FS?
Postby Dovale » Mon 12. May 2014, 18:11
Q is pitch
R is roll f is pause (0 or 1)
here is a sample
<R+009.6
<Q+010.9<R+010.6?f0
<R+011.6
<Q+011.0<R+012.5
<Q+011.1<R+013.5
<Q+011.3<R+014.6
<Q+011.4<R+015.5
<Q+011.6<R+016.4
<Q+011.8<R+017.3
<Q+012.0<R+018.1
<Q+012.2<R+019.0
<Q+012.4<R+019.8
<Q+012.7<R+020.6
<Q+013.0<R+021.4
<Q+013.3<R+022.2
<Q+013.6<R+023.0
<Q+013.9<R+023.7
<Q+014.3<R+024.3
Ihave to learn how to load pictures and will send
hope it helps
Dovale
Dovale
Postby Dovale » Mon 12. May 2014, 18:12
The data format is 3 to 9 characters with a letter in the beginning
Dovale
