Postby RacingMat » Wed 4. Dec 2013, 10:58
Hello Vell001!
Great! Good project! You will have fun :D
I didn't find in the specs the power of the NIDEC motors I use.
But if you don't want to order the NIDEC motors, you should ask for truck or bus wipers ;-)
If the prices are the same for you as Tombo ;-), don't hesitate to test... For me I didn't find below 25€, so I bought new motors @35€!
Mat
Postby vell001 » Wed 4. Dec 2013, 16:35
Thanks RacingMat! I just bought some things today,
arduino , PSU and MotoMonster board.
Tomorrow, I will order two 30w wiper motors.
Hope that power can meet the requirements
vell001
Postby RacingMat » Wed 4. Dec 2013, 22:22
vell001 wrote:I just bought some things today
Happy Chrismas ;)
Postby prodigy » Thu 5. Dec 2013, 00:18
Yup, I would also suggest new wiper rather than junkyard. I found mine over ebay, 25€ each, new, from Skoda, working like charm.
Postby vell001 » Thu 5. Dec 2013, 07:01
I have already order 2 new wiper-motors [12v 30w], just waiting for the delivery...
In the emotional
vell001
Postby RacingMat » Thu 5. Dec 2013, 20:49
Yes! Waiting is boring
Postby vell001 » Sat 7. Dec 2013, 07:52
Hi,RacingMat
My arduino finally arrived, but I have some problem.
I find a post [http://www.x-sim.de/forum/viewtopic.php?t=723] ,this post inside the arduino code is different from yours. Seems to be two kinds of implementations. yes or no? And which implementation I should chose?
vell001
Postby Tombo » Sat 7. Dec 2013, 10:21
i'm not Racing Mat but i try to answer. These are two different codes but you can use both with arduino and Motomonster.
Racing Mats firmware uses the Uso output and Xpid uses Synaptrix.
With Racing mats Firmware you can Stick the Monster Moto directly into arduino and it will work. The Xpid Firmware you must connect the Right Pins with wires. You can test both and use the one that you prefere. For First testings i would recommend Racing mats firmware. Its easy to test and very well explained by him.
Tombo
Images: 36
Postby RacingMat » Sat 7. Dec 2013, 12:03
Thanks Tombo! :-)
I try to keep it the simpliest as possible.
So, the code is shorter and simplier and I have detailled the step-by-step tests and setup in my post.
Tombo is a good adviser as he tested both! ;-)
Postby vell001 » Sat 7. Dec 2013, 15:46
Tombo wrote:Hi,
thank you very much! I got it. I have been reading RacingMat's code,the basic can understand. Waiting for my delivery...
thanks again
vell001
