sound in effect
sound in effect
Postby scottlolo » Sun 12. May 2013, 19:52
who could fabricate a plugin to transform sound of games or of the pc in effect.;) ;)
for s to serve in axle Y.
D-BOX uses sound of games to create a movement.
scottlolo
Images: 5
Re: sound in effect
Postby scottlolo » Mon 1. Sep 2014, 20:28
sound piste and motor vibration in axe effect y for game
scottlolo
Images: 5
Re: sound in effect
Postby RacingMat » Wed 3. Sep 2014, 15:28
Hello,
What are you calling "axis Y"? vertical axis?
Why are you trying this way? It will give you wrong information: bass sound will give high amplitude. What is the reality behind this?
Xsim already gives you the "perfect" values from telemetry data...
yours,
Mat
Re: sound in effect
Postby scottlolo » Wed 3. Sep 2014, 18:26
C EST L AXE VERTICALE POUR UN JEU QUI NA PAS DE PLUGIN COMME WRC4
COMME CA QUAND ON ACCELERE LE SON AUGMENTE LA COURBE DANS MATH PLUGIN,MAIS C EST JUSTE UNE IDEE COMME CA.
:D
scottlolo
Images: 5
