codemasters plugin
codemasters plugin
Postby motiondave » Wed 1. May 2013, 03:09
Ok, will some one PLEASE ANSWER THIS!!!
I have looked in the plug in file of x-sim and looked at the drop down list of extractor.
I see a RD grid plug in,
I see a codemasters plugin.
What is the line of code change for rd grid
what is the line of code change for codemasters
Also, is the codemasters plug in the replacement plugin for dirt 2 plug in. As there is no listing for dirt2 plug in anymore in drop down list in extractor.
I use life for speed plug in for dirt (s) currently as no one has clarified what plug in I am supposed to actually use.
Also, am I still required to copy paste the plug in from x-sim folder to game folder.
Re: codemasters plugin
Postby sirnoname » Wed 1. May 2013, 03:18
Yes, the codemaster is a replacement because it works with more games than dirt2.
You can go to the subfolder with the wizard scripts and open the fitting file to have a look what is exchanged.
The codemaster extradata .txt files.
The fixes are also interesting because they set back LFS to extradata=1.
Grid has another plugin and is pre-dirt2.
Grid2 should have LFS and Codemaster.
LFS plugin does not deliver gauge data.
Postby motiondave » Wed 1. May 2013, 04:45
Thanks for that info, but am I still required to copy paste plug ins into program folder.
And again, what are the respective line of code changes I need to mod in hardware settings config.
Postby sirnoname » Wed 1. May 2013, 12:28
All codemaster games do not need to copy any plugin anywhere. Only the change of that line that is displayed in the script do the trick.
Postby motiondave » Wed 1. May 2013, 14:32
ok fellas thanks for that.
It will help other wishing to set up codemasters games
Postby sirnoname » Wed 1. May 2013, 15:09
You can make your own set of script files that exchange the codemaster setup and place the LFS setup.
The dokumentation HowTo is here:
http://www.x-sim.de/software.php?lang=e ... umentation
http://www.x-sim.de/documents/Howto-gam ... cripts.txt
Such a package can be loaded into the script directory, the wizard will scan the disk and exchange all needed parts for you. (disk wide, all directories or special ones, as you like)
Users browsing this forum: No registered users and 27 guests
