Bass Shaker Plugin  Topic is solved solved with post #19108
Bass Shaker Plugin
Postby Riton » Mon 7. May 2012, 23:00
hello,
I would like to discuss the operation of the Bass Shaker Plugin.
I find that the operation with XSIM is opposite operation with the soundtrack of the game
With the soundtrack of the game, the big shocks are in the low frequency and very high volume.
With XSIM, it's the opposite.
With Xsim:
With the test tablet i can see this configuration.
Uploaded with ImageShack.us
I need to put low frequency in big bump and hight freqency in little vibration , little bump.
with the original configuration i don't find a solution in the profile.
I think this configuration is better for best feeling:
Is there possible to change the pluging? or can someone give me a solution ?
thanks
Riton
Images: 70
Been thanked: 16 times
Re: Bass Shaker Plugin
Postby Riton » Tue 8. May 2012, 19:51
Ok I will do my photo album.
Yes I reversed the effects, but it does not reverse the frequencies in Xsim.
my diagram gives the test tablet and operation with XSIM.
as I explained, the operation should be like that with the soundtrack.
small effects, small vibration.
big effects, big vibration
It would be interesting to adjust the frequency range of the plugin in reverse order.
Riton
Images: 70
Postby sirnoname » Wed 9. May 2012, 21:14
The engine has smaller unbalance if it is faster, so you have less jitter.
I do not see your idea behind the volume or the sound frequency in combination to speed or acceleration.
Perhaps it make sense to use the RPM?
Postby Riton » Wed 9. May 2012, 23:17
if you are using for example the effect 26
in the current configuration of the plugin, the low frequencies are at the center of the curve to the 0/0%
the small effect of track are currently low frequencies to 20 Hrz.
this is not optimal for representing small effects.
we should have little effect for the high frequency to 220Hrz
In my first diagram, you can see the actual configuration with the bass shaker plugin,
big effect in the game is a hight frequency like 220 HZ, so it's better is i can have in the place a low frequency like 20Hrz.
My second diagram see a better solution .
with this we have a better solution to use all effect like a motor
I hope your understand
Riton
Images: 70
Postby Riton » Sat 9. Jun 2012, 12:50
I have make a vidéo with ButtKicker LFE Kit and game sound track:
http://youtu.be/OUIUYlA6tG4
I want to make progress in the setting with the ButtKicker LFE XSIM Kit But I don'' can not make a good setting because I do not understand. My testing shows that an working can not I have to practice correctly with effects. I take the example of the effect 26 and I can not feel properly has the bumps and the track. I am always looking for help, visual examples .... discuss this topic to properly set, or To give the basis for its proper settings
Riton
Images: 70
Postby motiondave » Sat 9. Jun 2012, 14:44
Riton wrote:I have make a vidéo with ButtKicker LFE Kit and game sound track:
Ok, so are you using effect 26 for motion? If so, let auto adjustment "find" a number. Just go for a short , slow drive to get a number, then untick auto adjust and start the motion. Test and increase or decrease the number and work with % of effect.
Try the same principle for the buttkicker.
Postby Riton » Mon 11. Jun 2012, 20:08
Google TraductionThank you for your help.
I did that, of course, but there is a problem.
for example for effects values ​​of 1000:
I made a diagram to show what happens to output sound card, depending on the values ​​of effects.
you can see on my schema:
small effects values ​​correspond to low frequencies 20 Hz
and large values ​​correspond to effects of high frequency 200Hrz
it is difficult to obtain correct effects, with frequency values ​​reversed.
How to have a sound variation of a high frequency to low frequency with this mode of operation.
for me, a big shock is a low frequency:
this is a variation of high frequency to low frequency.
a bump,
this is a variation of frequency, to a low frequency
Français:
Merci de ton aide.
j'ai fais ça , bien sur, mais il y a un problème.
par exemple pour des valeurs d'effets de 1000 :
j'ai fait un schéma pour montrer ce qui ce passe en sortie de carte son, en fonction des valeurs d'effets.
tu peux voir sur mon schéma:
les petites valeurs d'effets correspondent à des fréquences basse 20 Hz
et les grandes valeurs d'effets correspondent a des fréquence haute 200Hrz
c'est difficile d'obtenir des effets correctes, avec des valeurs de fréquence inversé.
Comment avoir une variation sonore d'une fréquence haute vers une fréquence basse avec ce mode de fonctionnement.
pour moi, un gros choc est une fréquence basse :
c'est une variation de haute fréquence vers basse fréquence.
une bosse ,
c'est une variation de fréquence, vers une fréquence basse
Riton
Images: 70
Postby Riton » Tue 25. Sep 2012, 22:02
+1
Riton
Images: 70
Postby Riton » Fri 12. Oct 2012, 16:31
I would like to discuss on this topic, but nobody seems interested to experiment with me and share his opinion ...
I have already given my opinion and my tests without much reaction, I think nobody uses
or maybe just for the noise of the motor (rpm)
The plugin could probably be improved, because at the moment, the result is better using the sound of games.
It's a shame, I think this plugin could really be a huge plus in the simulation effects.
* is the competitor of this plugin, but there is no trial version, which is a shame.
Riton
Images: 70
Postby yokoyoko » Fri 12. Oct 2012, 17:14
I plan to do the same thing. I ordered 4 bass shakers. I own various multichannel soundcards and amps.
Will come back here if the shakers arrive. No experience so far, sry.
Best regards
Yoko
