NetKar Pro
NetKar Pro
Postby skape » Sat 24. Nov 2012, 14:06
Hello, I have a Fex-Like who work with X-Sim anf I want to know if there is a solution for NetKar Pro.
Thx
skape
Re: NetKar Pro
Postby sirnoname » Sun 25. Nov 2012, 14:06
Hi skape,
generally the graphic driver ist doing this job good because there is no 3D menu and it can trigger the track if 3D is available.
But if you like to get a sort of plugin we have here the rule that the community search for solution of their favor game.
This means you go to your game directory, search for addon or plugin folders and ask in the forum of the game where source code or details are available.
In nkpro case the big question is the "nkserverrecorder.ini" which seems to transfere some unknown data.
Find out which way (e.g. network or memory exchange) and which data, then we can continue. Find forum posts and infos. Normally the community has better connections to the game developer. Try to find a person in the game forum which is a good poster and has the knowlege. Ask persons who have connections to the developers. If you do not ahve any connections, make them. Tell them the way we use smartphones/tablet gadgets and make it worthfull for them.
The AIM interface is a logger tool and not realtime. Correct me if I am wrong.
Best regards,
SirNoName
